10-23-2015 01:58 AM - edited 03-17-2019 04:40 AM
Hi all,
I am trying to connect an analogue phone to my Cisco router through a VIC3-2FXS card plugged on slot 3. Router runs Version 15.4(3)M3, RELEASE SOFTWARE (fc2).
I have tried a couple of different phones but I cannot get any dial tone.
Here my conf
#sh run
voice-port 0/3/0
ring cadence pattern01
cptone GB
caller-id enable
dial-peer voice 1001 pots
destination-pattern 1001
fax rate disable
port 0/3/0
#sh voice port sum
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 1 bri-voice up dorm none none y
0/0/0 2 bri-voice up dorm none none y
0/0/1 1 bri-voice up dorm none none y
0/0/1 2 bri-voice up dorm none none y
0/3/0 -- fxs-ls up dorm on-hook idle y
0/3/1 -- fxs-ls up dorm on-hook idle y
Any idea?
Thank you very much
Solved! Go to Solution.
10-23-2015 11:51 PM
Are you sure that the pin out on the phones match the FXS ports?
For more information about this see this url, http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/7938-2fxs-vic.html#info
10-23-2015 03:37 AM
Please try the suggestions in the following links
https://supportforums.cisco.com/discussion/12037001/no-dial-tone-fxs-cisco-2911
http://www.cisco.com/c/en/us/support/docs/voice/h323/22372-no-dialtone.html
Manish
10-23-2015 07:35 AM
Hi Manish,
many thanks for your reply
I checked the links provided. I am not using STCAPP. As you seen before, If I do show voice-port summary, I see the port in on-hook state. However, if i lift the receiver it doesn't change the state it remains in on-hook and there is no dial-tone; I've reinserted the voice module card in and swapped the slots without any joy.
I also have a couple of IP phones (7821) connected on the router and they are both working ok.
This is the output of
#sh voice dsp
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
*DSP SIGNALING CHANNELS*
SP2600 001 05 {flex} 37.3.6 alloc idle 0 0 0/3/0 02 0 152/0
SP2600 001 06 {flex} 37.3.6 alloc idle 0 0 0/3/1 02 0 56/0
On the second link, how can I check on IOS if I have the feature IP Plus or Enterprise Plus?
Thank you
10-23-2015 08:20 AM
can you please post the output of below command
#show voice dsp group all
#show voice dsp error
enable the below debug and shut and no shut the port, go off-hook and see the behavior. if still same collect the debug post the same.
debug voice vtsp all
debug vpm signal
Br,
Nadeem
10-26-2015 01:51 AM
Hi all and thank you for you help
I've tried a couple of different RJ-11 cables working on other phones. The led on the back of the router doesn't lite up.
Nadeem, i turned on debug you asked and sh+no sh the port + off hook but nothing comes up.
Here's the commands output for
#sh voice dsp group all
#sh voice dsp error
#sh diag
#sh ver
Thank you
10-23-2015 01:16 PM
Hi Paolo.
Please look at the led near the port.
Does the led lite up when you go off hook?
Please post the output of a show diag and show ver.
Please provide also logs as Nadeem requested.
Carlo
10-23-2015 11:51 PM
10-27-2015 02:13 AM
Hi all,
I brought in a tester and I found out that I have +44V. I plugged in a adapter with pins splitter and I check pin by pin. Using an adaptor, going from RJ-11 to RJ-45 back to the analogue phone I have my dial tone and telephony is working ok. I'll make a suitable RJ-11 cable.
Thank you guys for your help.
