Showing results forĀ
Search instead forĀ
Did you mean:Ā
OverHead Paging, External Speaker solution
byronmcneil
Hello Tech's
Im looking for an external speaker solutions for overhead paging. The phones are 8811's and the enviroment is a clinic waiting area.
If there is a simple solution please provide an guide
mradell
Hello byronmcneil. What your asking isn't really directly related to the type of Cisco phones you have, but if you're using CUCM as your call agent the SNOM-PA1 is likely the simplest overhead paging solution I've seen. You can program it as a 3rd party SIP endpoint in CUCM, assign it a phone number, and then call it to page. You will also need a speaker to go with it (you can just buy a simple bullhorn style speaker), or it can drive an existing speaker, or it can hook to an existing paging amplifier.
Another solution is using something like Cisco Paging Server/Informacast to use the phones themselves as a paging system/speakers
mradell
As stated earlier---  Informacast has a good solution and can be utilized for other things to include Mass notifications of emergency situations, etc.   www.informacast.com
