Phone background Image Issue
waqas sardar
Hi Guys,
We are trying to change the phone background image but no luck.
- Applied image on common phone profile.
- Restarted tftp
Please find the attached logo and xml file.
7 Replies 7
Which model of IP Phone are you trying to change the background image?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Model is 8845
1) What is Image size?
2) Did you modify it to proper size? In which TFTP folder did you copy the image.
3) Did you Uncheck the Box Enable Background access to users in COmmon profile
4) Did you apply the common Profile to the phone an reset the phone?
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
George Sotiropoulos
I assume that you have followed the procedure that is described below:
https://community.cisco.com/t5/collaboration-voice-and-video/implementing-phone-background-images-for-cisco-ip-phones/ta-p/3115140
Can you clarify if you can change the image manually to a certain phone that is under the specific Common Phone profile?
If your answer is yes ie if you can manually change iy, then you should try uncheck the option "Enable end user to access phone background (Device -> Device settings -> common phone profile) and reset the phone(s).
Hope this helps,
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
waqas sardar
@Carlo Poggiarelli @HARIS_HUSSAIN @George Sotiropoulos
I have attached screen shoot for the common profile and phone.
Please check
Thanks.
The correct size for 88XX phones is 800x480x24 and because of a mistyping on the documentation, the  right dimensions is thumbnail is 139 pixels (width) X 109 pixels (height)
So modify the List.xml into
<CiscoIPPhoneImageList>
<ImageItem Image="TFTP:Desktops/800x480x24/tn-emrill.png" URL="TFTP:Desktops/800x480x24/emrill.png"/>
</CiscoIPPhoneImageList>
Also make sure to modify both the image and the thumbnail size.
Put them into Desktops/800x480x24/ tftp directory and you should be ok
Please let me know
Carlo
@Carlo Poggiarelli  Background image shows on phone now but there is little cut from the down image.
