03-18-2023 12:23 AM
We have ISR4331-V/K9 router with 10 cisco ip phones connected to it, it was working fine without any issues the suddenly phones stopped working, my question is do we have to purchase a license to make phones work with standard features?
Solved! Go to Solution.
03-18-2023 01:29 AM
Note that the basic voice bundle router ISR4331-V/K9 does not include Callmanager Express licensing. If ordered with the router the SKU is "CME-UL" "Cisco Communication Manager Express (CME) - 1 CME Endpoint License" and quantity needs to match the number of extensions. Your Cisco partner can advise, and also deal with supplying licences separately if this is an existing router.
https://community.cisco.com/t5/ip-telephony-and-phones/isr4331-v-k9-users-license/td-p/3989972
03-18-2023 02:58 AM
If your router is smart license mandatory version after the evaluation period the phones will stop working.
Starting with CME version 12.5 (Cisco IOS XE 16.10.1a), all platforms must be registered with a customer’s Cisco Smart Software Management account
You must get the Licenses 10 quantity as mentioned below.
03-18-2023 04:30 AM
03-18-2023 01:29 AM
03-18-2023 02:58 AM
03-18-2023 04:30 AM
Yes you do.
