05-18-2016 01:44 PM - edited 03-17-2019 06:58 AM
Hi Guys,
I am trying to integrate the CUCM 10.5 with UCCX 10.6 and am receiving the follow message:
"Cisco Unified CM Authentication Failed because of CCMAXL expection.
Please check the logs for details"
I created the application user AXL in CUCM, but, I don´t know what permissions is necessary application in the user need have.
Can I help me? I read the procedure below, but, not is detailed as should configure in the CUCM
Wilson
Solved! Go to Solution.
05-19-2016 10:12 AM
What is the exact version of UCCX and CUCM you are using there.
Deepak
05-19-2016 11:06 AM
Hi Wilson,
Can you try to go on www.cisco.com/go/license
Select get other licenses--> Demo & Evaluation
Cisco Unified Contact Center Demo license
Select 10.6 as version and the feature set you prefer and download it
Please let me know
Carlo
05-18-2016 03:07 PM
Hi Wilson,
did you add standard axl api access role to that user?
Let me know
Carlo
05-19-2016 05:11 AM
Hi Carlo,
Yes, the standard axl api access role is configured. I am attached the print
Wilson
05-19-2016 10:12 AM
Deepak
05-19-2016 10:28 AM
Hi Deepak,
I inclued in the group Standard CCM Admin Users and worked. Now my problem is with the next step what is about license. I tryed put for 05 licenses models:
ccx90_enh_demo.lic
ccx90_ivr_demo.lic
ccx90_pre_demo.lic
ccx90_std_demo.lic
ccx100_pre_demo.lic
and are appear the same message for alls:
Warning: No valid license feature lines found in the uploaded license(s).
Validation completed.
The license cannot be added because, either the license config repository cannot be accessed or the license is invalid. Please specify a valid product license to continue.
Thanks a lot,
Wilson
05-19-2016 11:06 AM
Hi Wilson,
Please let me know
Carlo
05-19-2016 11:37 AM
Hi Carlos,
The license worked.
Thanks a lot,
Wilson
05-19-2016 11:51 AM
Yes...
Licenses contained on installation iso are totally unuseful for 10.6 cause they are for version 9.0 and 10.0 :(
I also opened a Tac in the past for that.
Glad you solved your issue and thanks for nice ratings
Cheers
Carlo
05-19-2016 10:20 AM
Hi Wilson,
It also happened to me once.
Try to use a differet password that is not on linux dictionary.
Let me know
Carlo
05-19-2016 10:29 AM
Hi Carlo,
As I told for Deepak I not needed change password only included the new group, but, now my problem is about license.
Wilson
05-18-2016 05:09 PM
AXL API access role needs to be defined to that user, also check if the AXL web service is activated.
05-19-2016 05:10 AM
Hi Venperun,
The AXL API is configured
Wilson
05-18-2016 11:20 PM
Simply provide Standard CCM Super Users role to the Application User that you are using for AXL communication. Apart from this, just make sure that userid and password match on both the sides i.e., UCCX and CM
Deepak
05-19-2016 05:10 AM
