04-15-2013 09:23 AM - edited 03-16-2019 04:48 PM
I already configure 8945 device profile for EM in cucm 8.6 and done all steps ,when I logging from the same 8945 it's logged successfully but the problem is when I try to logging from another ip-phone series ex: 6921-7975-7931 it's failed.
Thx
04-15-2013 10:27 AM
What happens when you try and login on a 6921 phone? Any error messages? What firmware is the 6921 using? If it's 9-3-3 you need to have installed the device pack for all features to work.
04-15-2013 10:34 AM
Also, have you created a Default Device Profile for the other phone models? I do not believe most of those model support Feature Safe/Line Safe so they would need a Default profile of that model to consume instead.
Please remember to rate helpful responses and identify helpful or correct answers.
04-16-2013 03:55 AM
I already created default device profile
04-16-2013 03:54 AM
Firmware on 6921 is 9-2-1-0
04-16-2013 04:01 AM
Also when I try to set pin it show me an error (XML error [4]:Parse Error
04-16-2013 08:50 AM
i am also getting similar error for few 7942 phones at the time of login to the EM.
As per Cisco documents, the error is related to the URL configured for EM services; but if that is the case than all of my phones should give similar error which is not the case.
