12-06-2023
02:08 PM
- last edited on
12-06-2023
04:52 PM
by
shule
I'm a noob, so I have a noob question. When you "generate PRT for selected", where does it go? I can generate one from the phone and then web in an grab it, but how do you generate one from the GUI? See below please and thank you.
Solved! Go to Solution.
12-06-2023 11:46 PM
12-07-2023 06:56 AM
And to follow on with what @b.winter said, the Customer Support upload URL field is on the device's configuration page, but can also be set system-wide via the Enterprise Phone Configuration, or per-group using Common Phone Profiles.
Maren
12-06-2023 11:46 PM
12-07-2023 06:59 AM
Thank you very much, it was driving me crazy.
12-07-2023 06:56 AM
Maren
12-07-2023 07:00 AM
Thank you for that follow up. I was actually looking for that as you responded.
