PVDM4-32 support on Cisco 3900 series voice gateway
anil.nangia
Is PVDM4 supported on 3900 series voice gateways?
Regard's
Anil
8 Replies 8
Chris Deren
 No, only on ISR 4Ks, you need PVDM3s for ISR G2s (3900, 2900).
Hi Chris,
Thanks, is it documented somewhere?
If so, could you please provide the document or URL for the same.
Regard's
Anil
Hi Chris,
These document doesn't say that it is not supported on 3900 series.
it's only says about 4K.
and if you see this document it says PVDM3-32 replacement is PVDM4-32 which again creates confusion.
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737888.pdf
Regard's
Anil
Exactly, it only talks about 4Ks as those are the only platforms running PVDM4s, sorry I am unable to locate better documentation, perhaps someone else will have better ones or can be more convincing.  Or you can contact your Cisco account team for official clarification.
Hi Chris,
Thanks again for valuable suggestion, will also try to find out the doc on it.
The datasheet doesn't list support for it for 3900 series router models.
https://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/data-sheet-c78-729824.html
The replacement part might have been meant for 4000 series routers and looked a little confusing because it was a breakdown for parts.
Refer this link:
https://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/eos-eol-notice-c51-737830.html
HTH,
Aeby
Please rate if you find this helpful.
Aeby
If a doc does not list a card/module as supported, it means that it is not supported. On a lot of occasions, you won't have the doc specifically list that it is not supported on X when it already states that it is supported on Y only.
