Register 887VA-V's FXS as SCCP to CUCM 9.1
dwtcp
Hi all,
i don't know if it is so obvious but i really can't find a solution!
And i can't find enough discussions so that means that i am completely wrong or nobody has tried it before.
I can see that my CUCM 9.1 offers 887VA-V subscription as SCCP gateway subscription.
Also, it offers a module VWIC-SLOT and then ports 0/0/0 through 0/0/3.
Therefore, if i enter the last 10digits of my 887s SCCP source interface mac-address, it creates a Device: AN1234567890000 through AN1234567890003
BUT,
my 887's config, which has fxs port 3 to 6 produces devices with names:
AN1234567890080 to AN1234567890083!!
What am i doing wrong.
Please advise:
IOS:c880voice-universalk9-mz.151-4.M4.bin
CUCM: 9.1.2(X)
I was aware of the same but I though of sharing so that if u could get some clue.
If the problem is there, please open the case and share findings.
regds,
aman
7 Replies 7
Hi.
Can you please share the output of a show voice port summary?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
here is the output:
vgw-r1#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
1               1   bri-voice   up    dorm none     none     y
1               2   bri-voice   up    dorm none     none     y
2               1   bri-voice   up    dorm none     none     y
2               2   bri-voice   up    dorm none     none     y
3               --  fxs-ls      up    dorm on-hook  idle     y
4               --  fxs-ls      up    dorm on-hook  idle     y
5               --  fxs-ls      up    dorm on-hook  idle     y
6               --  fxs-ls      up    dorm on-hook  idle     y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/3          1      efxs     up    up   on-hook  idle     y
50/0/4          1      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
50/0/6          1      efxs     up    up   on-hook  idle     y
50/0/7          1      efxs     up    up   on-hook  idle     y
50/0/8          1      efxs     up    up   on-hook  idle     y
50/0/9          1      efxs     up    up   on-hook  idle     y
50/0/10         1      efxs     up    up   on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
Not sure, if this biug is somewhat related to your issue.
CCMGW page7.1 says fxs 0/0/0-3 port instead of GW voice-port 0-3
CSCta03837
Hi Aman,
this bug refers to MGCP configuration.
For SCCP, i choose the same about subunit but it CUCM creates 4 ports named:
0/0/0, 0/0/01, 0/0/2 and 0/0/3.
 This means that the last 3 digits of the SCCP device that CUCM creates (and cannot be altered) are 000 to 003.
But, as i told you in my previous email, port 3 in 887VA-V is created with 080 suffix (and port with 083 suffix)!
vgw-r1#show stcapp device summary
Total Devices:           2
Total Calls in Progress: 0
Total Call Legs in Use:  0
Port       Device          Device   Call          Dev     Directory   Dev
Identifier Name            State    State         Type    Number      Cntl
0/1/0      AN542DEA5DF6080 OOS      UNREGISTERED  ALG                 UNKN
0/1/3      AN542DEA5DF6083 OOS      UNREGISTERED  ALG                 UNKN
                                           IN       OUT
vgw-r1#
Cheers,
Anthony
regds,
aman
thanks for updates.
can u please share output of command show stcapp device summary and snapdhot from CUCM?
regds,
aman
dwtcp
Hi all,
it is a known bug with id CSCul59124 similar to the one regarding MGCP registration.
DO NOT add 887VA-V as 887VA-V but as 881/886/887.
Then, add FXS in subunit 1 and not 0.
This action, creates an analog device with suffix in the range 080-083.
Anthony
