Registring Cisco Phone
cisco.plus
Hello
I am fresh on Voice, deployed CME on 2851 Router. I am unable to register cisco phones, Other SIP phones where succcessfully registered. DHCP is running on Windows 2008 Server.
ephone-dn  10  dual-line
number 6100
label CiscoPhone
name demo_cisco_phone
ephone  10
mac-address 0021.553F.03B1
type 7921
button  1:10
best wishes
CP
6 Replies 6
david-lima
Level 4
Level 4
Does WIN DHCP server has option ip 150 configured? and Do you have max-ephone and max-dn configured under telephony-services mode?
hth
David
Yes I got Option 150 configured and max-ephone and max-dn configured. Do we need to have any sort config file on the CME router for each phone model.
When you do a 'create cnf-files' under telephony service after giving all the ephone-dn and ephone commands, the system should automatically generate the config files.
Nitesh
PS:PL rate helpful posts
nitsinha
Level 4
Level 4
Run 'debug ephone register' on the CME and check whether the phone even tries to contact the CME for registration. If it does  not, you might want to look at the TFTP ip address on the phone. Check whether it points to the CME.
Nitesh
PS:Please rate helpful posts
I plugged  ip phone 7941 and outgoing call not working. I am able to receive calls.
with SIP phones incoming & outgoing calls are working ( softphones and SIP Ip Phones )
ephone-1 Mac:04FE.7F69.27D6 TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 12 and Server in ver 8
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:192.168.1.100 52040 7941   keepalive 57 max_line 2
button 1: dn 1  number 6110 CH1   IDLE         CH2   IDLE
ephone-dn  1  dual-line
number 6110
label Cisco Phone
name Cisco_IP_Phone
ephone  1
mac-address 04FE.7F69.27D6
type 7941
button  1:1
show flash:
-#- --length-- -----date/time------ path
1     44948728 Mar 29 2010 08:47:26 +03:00 c2851-spservicesk9-mz.124-15.T12.bin
2         2903 Mar 29 2010 08:55:28 +03:00 cpconfig-38xx.cfg
3      2324992 Mar 29 2010 08:55:42 +03:00 cpexpress.tar
4         1038 Mar 29 2010 08:55:52 +03:00 home.shtml
5       115712 Mar 29 2010 08:56:02 +03:00 home.tar
6       793739 Mar 29 2010 08:56:12 +03:00 256MB.sdf
7      1697952 Mar 29 2010 08:56:26 +03:00 securedesktop-ios-3.1.1.45-k9.pkg
8       415956 Mar 29 2010 08:56:38 +03:00 sslclient-win-1.1.4.176.pkg
79433728 bytes available (50315264 bytes used)
Outgoing calls to where ?
Always include FULL details.
