Route straight to System Directory Handler
aguy
Beginner
Beginner
Hi. Im trying to figure out how to route calls directly from a user calling an extension to a System Directory Handler.  eg: user calls dn -> directory handler answers -> the user can search the directory for other users.
I dont want voicemail or a call handler.  Is this possible?  How exactly is it done if possible.  Ive tried different setups and nothings worked the way i want.
Im using Call Manager 8.6 and Unity Messaging 8.6.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Use call routing rules to do that.
java
if this helps, please rate
Jaime Valencia
java
Still having issues with calls going straight to the DN's voicemail.
eg:
New User DN = 1234 w/ mailbox
Created a Direct Routing rule with the following attributes:
-Dialed number = 1234
-Active rule
-Send call to AD
-ln order of Precedence new rule is listed before other Direct Routing Rules
When I call 1234 it still goes to the generated voicemail box.  What am I missing?  Is it somehow not matching 1234 when calling in?
Figured it out.  It works as a Forwarded Routing Rule instead of a Direct Routing Rule.  Doesnt make sense but whatever.
Recognize Your Peers
