05-03-2017 11:24 AM - edited 03-18-2019 12:14 PM
Hi All,
Can anybody fill us in on this error we're getting from RTMT?
RTMTSessionsExceedsThreshold has occured. Counter SessionsActive of Cisco Tomcat Web Application(ast) on node X.X.X.X has value of 398 which is over high threshold 250
Appreciate it.
Tom
05-03-2017 11:35 AM
High seems that your tomcat service is having leak which is causing AST concurrent sessions to go higher than the configured threshold which is 250. This is triggering the alert. I believe RTMT won't be responding and generating the desired alert.
I remember seeing this case in one of the posts but don't have the bugID. But worth looking at it in bugtool kit or opening a TAC case to recommend workaround or upgrade to fixed release.
05-03-2017 06:52 PM
I opened a TAC case on this and the engineer said it's harmless. We can simply increase the threshold to say, 450, to get rid of the alerts.
05-03-2017 11:45 PM
Is Memory or CPU Utilization High due to Tomcat ?
05-04-2017 01:48 AM
That's true unless your memory usage is high which means that you have a memory leak. If your CPU/Memory are good then you can increase the threshold.
Please remember to rate useful posts
11-09-2017 08:04 AM
How do you know if your memory is good?
