Setting SNMP Contact and Location on CUCM 8.x
James Hawkins
Level 8
Level 8
I am trying to configure the SNMP contact and location setting on a CUCM 8.6 server.
This can be done from the CLI using the command utils snmp config mib2 add
This works fine when a single word is entered when a single word is entered - e.g. James and Cheltenahm
admin:utils snmp config mib2 add
ctrl-c: To quit the input.
Enter the sysContact information:: James
Enter the SysLocation information:: Cheltenham
Service Manager is running
SNMP Master Agent[STOPPING]
Commanded Out of Service
SNMP Master Agent[NOTRUNNING]
SNMP Master Agent[STARTING]
SNMP Master Agent[STARTED]
However when I try to enter multiple words it fails.
Enter the sysContact information:: James Hawkins
Enter the SysLocation information:: Cheltenham, United Kingdom
incorrect parameters
Syntax: /usr/local/platform/cli_scripts/snmpv3Commands.sh add_system <sysLocation> <sysContact>
    Note: to delete, leave <sysLocation> and <sysContact> blank
Cannot execute the command
I have also tried enclosing the strings in single quotes
Enter the sysContact information:: 'James Hawkins x245'
Enter the SysLocation information:: 'Home Lab, Cheltenham, United Kingdom'
and also double quotes
Enter the sysContact information:: "James Hawkins x2459"
Enter the SysLocation information:: "Home Lab, Cheltenham, United Kingdom"
System Contact cannot have double quotes. Please correct the entry
I have also tried enclosing the info within < >
Enter the sysContact information:: <James Hawkins x2459>
Enter the SysLocation information:: <Home Lab, Cheltenham, United Kingdom>
Does anyone know how to enter a string with spaces using this command?
brmeade
Level 4
Level 4
There's a feature request for this being tracked under CSCti13478.  You should talk to your Cisco account team to get more visibility on this if you need this functionality.
brmeade
Level 4
Level 4
Brian,
Thank you for your response. Hopefully it will be fixed soon!
Hello. I know this is an old thread, but I'm trying to understand how this is considered 'Solved' when the BugID referenced clearly states "No release planned to fix this bug". Was asked to help solve for this at a client site recently ... so these are still out there in production. -Chris
This bug 🐛 is still there in cucm. It is not yet fixed.
