12-14-2023 12:06 AM
Hi All
If I want 3 phones to share the same number in Webex calling, how is this done?
Does each need to have an individual extension and then all have a shared second number? or can they all have the same primary line?
Cheers
12-14-2023 12:08 AM
If you give them individual extensions, how should the devices share the same number then? ';)'
12-14-2023 12:26 AM
If you read what the OP wrote he is asking if phones can have a single directory number that is shared or if they need to have the shared directory number on the second line on the phones.
”Does each need to have an individual extension and then all have a shared second number? or can they all have the same primary line?”
12-14-2023 12:29 AM
But what's the difference between setting the shared number on the second line or the first line?
12-14-2023 12:47 AM
No idea, but that’s what the OP wrote and you’re answer was IMHO not at all reflecting that.
12-14-2023 12:57 AM - edited 12-14-2023 01:10 AM
If you search for shared line webex calling in your favorite search engine you'll find plenty of links to help.webex.com and also community post on this topic that likely can help you.
At the moment there seems to be some issue with the site where help.webex.com resides as all I get is a security warning that the page is insecure if I try to open one of the articles.
Hopefully Cisco will resolve that shortly.
12-14-2023 01:05 AM
12-14-2023 01:08 AM
@Ashish Patel That would likely be better if you would answer the OP @carl.townshend instead of addressing it to me.
12-14-2023 05:52 AM
Hi, I have been having a play with the above, virtual lines etc, it seems on Webex calling that the virtual line cannot be the "primary" extension of the user, which makes me thing they will need a dummy "primary" extension then the virtual line as the secondary etc, is this the case?
12-14-2023 06:26 AM
AFAIK a virtual line is not the same as a shared line. You might be mixing up the two terms.
12-14-2023 06:56 AM - edited 12-14-2023 06:56 AM
For devices (workspaces) registered with Webex calling, you can add the second line as a shared line, unfortunately not the primary line.
Also, have you tried assigning the same three phones to the same Webex user? All three phones should have the phone number of the user.
Shalid
Disclaimer:
Responses are based on personal knowledge and experience. Consider them as guidance. Other members may offer different perspectives or better approaches. No responsibility is assumed for outcomes; discretion is advised.
12-15-2023 12:43 AM
Hi Carl,
Associate the required number with an user and assign the user for all the 3 phones. By this way, you can have the shared line as primary on all the 3 phones.
Rajan
Please mark all useful posts as helpful and solutions as accepted wherever applicable
