01-30-2014
09:33 AM
- last edited on
03-25-2019
08:28 PM
by
ciscomoderator
Hi All,
Have a CUCM 8.6 BE (only Pub) and a Router (c2900-universalk9-mz.SPA.150-1.M6.bin). Both are configured to have SRST, and when accesing "Telephone Information" at IPPhone 6921 active server and inactive server are displayed in right order. But when WAN Link goes down, IP Phone does not come up with the inactive server,
Call-manager-fallback´s commands where accepted at router, and when "show ephone unregistered" is typed the IP Phone´s mac address appears.
Do I have missed something at Router, talking about License ?
Thanks in advanced
Solved! Go to Solution.
01-31-2014 12:19 PM
Also I don't think you posted your full configuration. Is this an MGCP gateway or h.323.
Check out this guide make sure everything matches up.
01-31-2014 03:07 PM
Hi Gregory,
It is an H323 Gateway and does not appear that info you under agreement.
01-31-2014 05:04 PM
Gerardo,
Your running configuration should look something like this
license udi pid CISCO2901/K9 sn FTXREDACTED
license accept end user agreement
hw-module pvdm 0/0
well at least it should in the newer version of code it should.
If you don't see it make sure do a
conf t
Make sure type yes or y
write the configuration (wr or copy run start)
If this does not work you may want to try updating your version of IOS code
01-31-2014 05:04 PM
Hi Gerardo,
can u post the show version/show running/show license feature /sh license detail output?
regds,
aman
01-31-2014 05:18 PM
Also do you have any phone at all registered you are setting your max-ephones low if you have other phones that are registered this would tell alot. Along with Aman request above.
Here is a sample from my last srst config if it helps
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
timeouts busy 16
ip source-address
max-ephones 42
max-dn 200 dual-line
01-31-2014 06:56 PM
Hi Gerardo,
Have a look at this discussion with similar problem.
https://supportforums.cisco.com/thread/2123996
In your case , IOS version is 15.0(1)M6
regds,
aman
02-04-2014 04:01 PM
Hi Aman and Greg,
It was solved, it was an IOS problem. But what about the following: "License Type: Eval Right to use" and the "Period Left " ???
02-04-2014 05:31 PM
Hi Perez,
thanks for update.
The ISR G2 comes with a 60-day evaluation license. After 60 days, the license changes to “right to use”.Is this what you are referring too.
what is the IOS version u are using now? can u share show version and show license detail cme-srst.
regds,
aman
02-04-2014 05:48 PM
Hi Aman,
So what will "rigth to use" mean, it means that will be active forever ???
Tomorrow i will share you the IOS version because right now Im out of the Clients´s site.
Thanks in advanced
02-04-2014 06:27 PM
Hi Perez,
SRST would be active forever now.
http://blog.vuurmuur.com/?p=32
Licensing functionality is working as per design here. Cme-srst licenses are honor based and hence you have to just accept the EULA. After the 60 days of EvalRightToUse the license will change to "right to use" for 12 years
regds,
aman
02-05-2014 11:31 AM
Hi Aman,
Attached send you the info you asked me. As you will see, even though with command "sho license detail cme-srts" appears the same "%Error: no license for cme-srst found - License feature not found" , with the command "sho license" appears as "Active" in the Index 11...
What do you think ??
Thanks so much for your support.
02-05-2014 11:49 AM
I think you are good now
Your error now looks like a typo
show license detail cme-srst not cme-srts
MTY_GONZALITOS_Branch_4082#sho license detail cme-srts
% Error: No license for cme-srts found - License feature not found
MTY_GONZALITOS_Branch_4082#conf t
Enter configuration commands, one per line. End with CNTL/Z.
MTY_GONZALITOS_Branc(config)#license accept end user agreement
MTY_GONZALITOS_Branc(config)#exit
Are you still having problems with SRST?
02-05-2014 11:58 AM
HI Greg,
Now it is working, so I just have the doubt.
Thanks man.
02-05-2014 12:03 PM
Well now hopefully now you are doubt free.
Aman gave you a couple +5 for your information on the SRST eval license.
02-05-2014 06:12 PM
Hi Perez,
thanks for the ratings.
You can try running the command show license detail cme-srst after 8 week and 3 days just to check the status again and share output.
Index 11 Feature: cme-srst
Period left: 8 weeks 3 days
Period Used: 20 hours 24 minutes
License Type: EvalRightToUse
License State: Active, In Use
License Count: 10/0 (In-use/Violation)
License Priority: Low
regds,
aman
