06-17-2019 01:17 PM
Appreciate if any one can advice on SRST configuration with COR.
SRST is working fine I need to restrict the PRI/Dialpeer to use based on the directory number
There are 2 departments say Dep1 with DN 1XXX and Department 2 with DN 2XXX
Department 1 to use PRI 1 for PSTN and Department 2 to user PRI 2
Please advice a best way to apply COR list under call-manager-fallback
Solved! Go to Solution.
06-18-2019 03:17 AM
Try below configuration:
name 911
name Local
name LongDistance
name International
For Department-1
dial-peer cor list Dept1-911
member 911
dial-peer cor list Dept1-Local
member 911
member Local
dial-peer cor list Dept1-LongDistance
member 911
member Local
member LongDistance
dial-peer cor list Dept1-International
member 911
member Local
member LongDistance
member International
For Department-2
dial-peer cor list Dept2-911
member 911
dial-peer cor list Dept2-Local
member 911
member Local
dial-peer cor list Dept2-LongDistance
member 911
member Local
member LongDistance
dial-peer cor list Dept2-International
member 911
member Local
member LongDistance
For Department-1
dial-peer voice 1001 pots
destination-pattern 911
no digit-strip
corlist outgoing Dept1-911
port 0/0/1:23
dial-peer voice 1002 pots
destination-pattern 9[2-9]……
corlist outgoing Dept1-Local
port 0/0/1:23
dial-peer voice 1003 pots
destination-pattern 91[2-9]..[2-9]……
forward-digits 11
corlist outgoing Dept1-LongDistance
port 0/0/1:23
dial-peer voice 1004 pots
destination-pattern 9011T
prefix 011
corlist outgoing Dept1-International
port 0/0/1:23
For Department-2
dial-peer voice 2001 pots
no digit-strip
corlist outgoing Dept2-911
port 0/0/2:23
dial-peer voice 2002 pots
corlist outgoing Dept2-Local
port 0/0/2:23
dial-peer voice 2003 pots
forward-digits 11
corlist outgoing Dept2-LongDistance
port 0/0/2:23
dial-peer voice 2004 pots
prefix 011
corlist outgoing Dept2-International
port 0/0/0:23
cor incoming Dept1-LongDistance 1 1001 - 1010
cor incoming Dept1-International 2 1011 - 1020
cor incoming Dept2-LongDistance 3 2001 - 2010
cor incoming Dept2-International 4 2011 - 2020
06-18-2019 03:17 AM
name 911
name Local
name LongDistance
name International
For Department-1
member 911
member 911
member Local
member 911
member Local
member LongDistance
member 911
member Local
member LongDistance
For Department-2
member 911
member 911
member Local
member 911
member Local
member LongDistance
member 911
member Local
member LongDistance
For Department-1
no digit-strip
port 0/0/1:23
port 0/0/1:23
forward-digits 11
port 0/0/1:23
prefix 011
port 0/0/1:23
For Department-2
no digit-strip
port 0/0/2:23
port 0/0/2:23
forward-digits 11
port 0/0/2:23
prefix 011
port 0/0/0:23
06-18-2019 08:22 AM
+5 to @Vaijanath Sonvane for a super-thorough answer!
06-18-2019 09:05 AM
