07-26-2011 09:49 AM - edited 03-16-2019 06:08 AM
I have a CUCM 8.0(3) cluster few hundred User Device Profiles and want to subscribe them all to a new IP phone service.
BAT does not have an update UDP option.
Is there any easy way to subscribe them?
James
07-26-2011 10:25 AM
Hi James,
When you create your phone service (Device > Device Settings > Phone Services > Add New Service) you can select Enterprise Subscription which will add the service to all phones in your environment.
HTH,
Chris
07-26-2011 10:35 AM
Thanks for the response. Unfortunately it will not work in this case as I only need UDP's for users at one site out of four to have the service (it is VoiceView Express for Unity Connection).
Any other suggestions welcome.
07-26-2011 11:00 AM
Hi James,
Here's another option, you can use the BAT Import/Export tool, in CUCM, go to BAT > Import / Export, click the Device Profile checkbox and export the data to a .tar file and edit the .csv file for the UDP. In the .csv file, you can update the following fields with the service you are looking to subscribe to:
Service Name 1 | Subscribed Service Name 1 | Subscribed Service URL 1 | Subscribed Service Name ASCII 1 |
You can then create another .tar archive (with the previous header.txt file used during the export) and upload that to CUCM and the config to the system using the Import/Export tool, and this time choosing the Import option and selecting the .tar file and the UDP checkbox.
HTH,
Chris
07-26-2011 11:02 AM
Hi Chris,
Thanks - I will try that tomorrow.
