Telephony service is unavailable - IP Phone model 8851
wilsonsant
Level 6
Level 6
Hi Guys,
The site is having in the IP Phones randomly the error message "Telephony service is unavailable". I don´t have sure, but, my suspect is related the network error. Any have idea about this?
Wilson
5 Replies 5
Gregory Brunn
Check phone logs what do you see?
Leo Laohoo
If this is a remote site, check for congestion to the WAN link.
Ratheesh Kumar
Hi there
Is this happening only for 8851 phones. Please post the console logs from the phones during the event. If this affects on a site mostly it could be WAN related issue. Try a continuous ping from the CUCM to the ip phone.
Also please check the Cisco Bug: CSCus85518 if you are hitting this.
https://bst.cloudapps.cisco.com/bugsearch/bug/%20CSCus85518
88XX phone can't register if more than 5 lines in phone button template
Description
Symptom:
8841 or other 88XX phone model that doesn't support a Key Expansion Module will show "Unprovisioned" or "Telephony Service Unavailable" and fail to register to Unified Communications Manager (UCM).
Conditions:
This issue only occurs if the Phone Button Template assigned to the device in UCM has more than 5 lines assigned to it. The 8841 and 8811 phones only support a maximum of 5 lines and will reject the xml configuration file from UCM if more than 5 lines are present.
Workaround:
Use a Phone Button Template in UCM that is based on one of the Standard 8841 or 8811 which will not allow more than 5 lines to be configured.
Further Problem Description:
Any 88XX phone running 10.2(2) or later will display "Unprovisioned" when no lines have been configured in UCM. This defect causes the phone to stop parsing the config file before it detects the configured line. Phone firmware older than 10.2(2) will show "Telephony Service Unavailable".
Look for these lines in the phone's console logs to verify this is the problem you are facing.
9024 ERR 15:13:11.916351 Jan 5 15:13:11 JAVA: configmgr MQThread|cip.xml.XmlParser: - XML Parser Exception: Element '/device/MissedCallLoggingOption' : String too long: length is 7, max length = 5 (line=225)
Hope this helps !!!
Cheers
Rath!
***Please rate helpful posts***
peggyfarrell
Hi everyone,
I use auto-reg on my cluster and got this message.  (Telephony service is unavailable);
I did find a workaround for an urgently needed VIP phone.
if you are using auto-reg - or once it is in the system.  After manually entering the MAC, I forced a downgrade to 11.X firmware, then got the message to 'check the network cable'.  Then forced the upgrade back to 12.x and the phones come online.
11.x= sip88xx.11-7-1-17
12.x=sip88xx.12-0-1SR1-1
shasmal18
Came across this error on 8811 phones that would not auto register.  The fix was to delete all unassigned DNs in the auto-registration range.
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/96102-registrationrejectederrordbco.html
