ā09-02-2012 12:54 PM - edited ā03-16-2019 12:59 PM
Hi All,
could you please tell me what are the options to connect Remote phones (1 per site) to the Central UC560? I am at the design step
What do I need for the remote sites?
REGARDS
GCA
Solved! Go to Solution.
ā09-03-2012 12:05 AM
Router to create VPN. Better if these, or the switches, have PoE.
ā09-03-2012 01:25 PM
Now I got that the 7945 can connect by VPN with an ASA to the CME8.x
What I don“t know is it is enough with the ASA Essential VPN License :
ASA-AC-E5505 | Anny Connect Essential vpn license ASA 5505 25 user |
Or if it is nescesary the premium one:
ASA5500-SSL-25 | ASA 5500 SSL VPN 25 Premium User License |
I Appreciate your help,
regards
ā09-03-2012 09:31 PM
You would need the SSL VPN licenses.
Even better, use a router instead of ASA, and need no licenses.
Note: doing phone VPN is very ver complicated and poorly documented. Better to place a small router at the remote site instead.
