05-11-2018 05:55 AM - edited 03-17-2019 12:48 PM
Hi, I have a customer that uses Route Filters and the GB dial plan. BT have introduced numbers that have a 01 after the area code, for example, 01274 01XXXX. The end user has CUCM version 9.1.2.
I am hoping that the latest GB numbering Dial Plan will include this but I don't want to advise the customer unless this is the case. How do I check?
05-11-2018 06:24 AM
You were on that major thread about the GB numbering plan a few years back. Can you answer this question?
05-11-2018 06:41 AM
05-11-2018 07:18 AM
Hi Nipun,
thanks for your reply. Offcom implemented the change from 1st October 2014. I think I will follow your suggestion and lab it up.
Thanks, John.
05-11-2018 07:07 AM - edited 05-11-2018 07:12 AM
Hi, you can just look at the flat file of the IDP on cisco.com to see the patterns that are there.
The latest one is dp-ffr.3-1-35.GB. I have looked at the flat file and there is no 01274. There is 01276 in it.I have attached the flat file for you,s o you can have a look through it.
05-11-2018 07:15 AM
Hi Ayodeji,
many thanks, I did look at the flat file but could not see the addition so perhaps I will lab for ver 9, add the DP and test out to a gateway.
Thanks, John.
05-11-2018 07:16 AM
Yes in that case your best option is just to add a manual pattern and send it out your gateway. Its that simple.
05-11-2018 07:21 AM
05-11-2018 07:42 AM
@johnsnave1 wrote:
Hi Ayodeji,
I did add a manual pattern but there are other towns in the UK that have had the area prefix changed so best to use the Dial Plan.
Many thanks for your responses and help.
Cheers, John.
There is no point "labbing" this up. The IDP doesn't contain the pattern. What you have in the flat file is what you have in the cop file. There is no other way to route calls for these new numbers without manually defining the pattern. You should just use 0127XXXXXXXX. Are you suggesting that there are multiple of these you need to add?
05-11-2018 07:50 AM
05-11-2018 08:37 AM
