12-08-2015 12:49 AM - edited 03-18-2019 11:43 AM
Hi All,
We installed the Cisco Prime Collaboration Assurance 10.6 . We got the below error while access from the firefox.
"Error code: ssl_error_weak_server_ephemeral_dh_key". We have done the workaround as mentioned in supportive documents.
But we couldn't take the SSH from Putty client. No Network Issues. Both Server & client are in the same subnet. Kindly advice.
Thanks in Advance !!!
Solved! Go to Solution.
12-08-2015 01:57 AM
From Prime Collaboration 10.6 Quick Start Guide:
"You can login through SSH using port 26 for Prime Collaboration Assurance and port 22 for
Prime Collaboration Provisioning."
Ref:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/10-6/quick/start/guide/C
isco_Prime_Collaboration_Quick_Start_Guide_10_6.html#reference_F5EAFA64BFA64FEB9DBC2F97103
1DA96
Deepak
- Rate Helpful Posts -
12-08-2015 01:57 AM
Ref:
1DA96
Deepak
