09-24-2013 05:40 AM - edited 03-16-2019 07:31 PM
my conf in attatchment files
and this is debug ccsip calls results
*Sep 24 12:54:01.339: //3636/3806C30E8EF1/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x47BAFFB4
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 0146239789
Called Number : 0530184647
Source IP Address (Sig ): 172.29.37.10
Destn SIP Req Addr:Port : 10.208.9.69:5060
Destn SIP Resp Addr:Port : 10.208.9.69:5060
Destination Name : 10.208.9.69
Disconnect Cause (CC) : 28
Disconnect Cause (SIP) : 484
*Sep 24 12:54:01.347: //3635/3806C30E8EF1/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x472E5E90
Called Number : 00530184647
Source IP Address (Sig ): 172.30.151.8
Destn SIP Req Addr:Port : 172.30.151.6:5060
Destn SIP Resp Addr:Port : 172.30.151.6:5060
Destination Name : 172.30.151.6
*Sep 24 12:54:01.347: //3635/3806C30E8EF1/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 172.30.151.8
Source IP Port (Media): 17688
Destn IP Address (Media): 0.0.0.0
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): 0.0.0.0:0
Solved! Go to Solution.
10-01-2013 01:02 PM
Hi Othman,
Feature is introduced in release 12.4(15)XY, after this release, IOS with voice features support the EO.
J Rosa.
10-01-2013 05:18 AM
For the first one please ask to ITSP or specific company because again call is being released from there side.
And for the second one please share complete end to end trace.
Nishant Savalia
10-01-2013 10:08 AM
Nishant
for second problem the outgoing call is established ok and i hear greating messages but i cant interact with auto-attendant
" Cant interact with outging auto-attendant calls , for example when make call to 909 ( customer service for stc ) and after automatic greeting message it ask me to press 1 for arabic and 2 for english , when i press 1 or 2 nothing happen and call terminated."
i try now to upgrade our router image ,
do you know what exact or right image for cisco router 2821 or 2851 to act as cube or ip-to-ip GW ?
tomorrow i will post what version i have on router .
10-01-2013 12:57 PM
hi
i found these links for choosing appropriate image
10-02-2013 12:04 AM
I think you already have CUBE functionality with the existing image but for that sip-early offer command if you want to upgrade image then you can do and test but mean while please send "debug ccsip all" before upgrading.
Please mention your CUCM IP address and IP address of remote end where you are routing your call.
Nishant Savalia
10-02-2013 01:00 AM
10-02-2013 05:09 AM
thanks to god
hi
Nishant Savalia
hi
J Rosa.
i made upgrade and it work fine for our two problems , i upgrade to this image
c2800nm-ipvoice_ivs-mz.150-1.M9.bin
thank you
Nishant Savalia &
J Rosa.
10-03-2013 08:16 AM
Good News Othman!
Please remember to rate helpful responses and identify helpful or correct answers.
Regards.
J Rosa
