Bookmark
Subscribe
909
Unity connection and CUCM
kingstdz
I have CUCM and unity connecion, configured auto attendent, work fine for XXXX extention in local side CUCM cisco, but when i give it XXXX XXXX of other side may be CISCO or ALCATEL (distant) does not work.
how i can config it and where in CUCM (it has route and plan ) or in unity connection?
i have mp3 réception (welcome) how i can transfert and codec it to unity connection?
thanks
As I don't know your setup and your dial-plan, all I can say is: Check the logs of the call in RTMT and use DNA to trace the call. Probably there is something wrong in your dial-plan (CSS, PT, cannot find the pattern, ...).
b.winter
Just use another RP with XXXX XXXX and strip it down to XXXX, before sending it to Unity.
thanks for reply
i think this rp exist on cucm bcz when i call from cisco phone to xxxx xxxx it work, when i call from mobile to number pstn auto attendant and i give it xxxx xxxx doesnt work, but with xxxx work fine.
thanks
