Unity Connection Marco Traces ?
yun zhang
Hi All
I'm working on to troubleshooting voicemail improperly issue on unity, I would like to enable marco trace on cisco unified serviceability , but i can't found any about that on there, anyone know this ?
Looks like you are looking at wrong place. The document says to look into  " Cisco Unity Connection Serviceability " which is different than " Cisco Unified Serviceability ".
GP.
8 Replies 8
Gajanan Pande
Yun,
Checkout following links depending upon your CUC version, I am presuming you are either on CUC 8.x or 9.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/troubleshooting/guide/9xcuctsg010.html
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/troubleshooting/guide/8xcuctsg010.html
If not, all versions guides are found here http://www.cisco.com/en/US/products/ps6509/prod_troubleshooting_guides_list.html
GP.
Pls rate the post if it helps !!
Hi Gajanan Pande
thank you for quick response, our unity connection version 8.5 , I think it should be supported marco traces.
Yes it indeed does. http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/serv_administration/guide/8xcucservag030.html#wp1050908
GP.
Pls rate all the posts by clicking on stars below them, if they helped.
Gajanan Pande
Dear
Step 1 In Cisco Unity Connection Serviceability, select Trace > Micro Traces.
The Micro Traces page appears.
see my Capture
can' t choose the marco trace for click
GP.
Dear  Gajanan
Thank you , It's my mistake. haha  I need to more chariness in futher. thank you very much!!
