Updated Question: Now Can 8945 IP Phones work with SRST?
gmgarrian
Level 4
Level 4
I can't find the 8945 listed on any compatibility matrix.
Update:
I can now download IOS 15.2.1T which I believe has SRST 8.6.  But according to this:
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps2169/data_sheet_c78-678873.html
the 8945's are still not supported.
Am I reading this wrong?
4 Accepted Solutions
Karthik Sivaram
Level 4
Level 4
hi,
8945  is supported from cme 8.8
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/phones/ps10998/ip_phone_comparison_matrix.pdf
cme 8.8 (15.2.1T) is likely to released by end of July this year.
Karthik
Unfortunately No.
8945 CME/ SRST will only work with cme 8.8 (15.2.1T)
Look at this link this is the link for the phones we support in  srst 8.6 .
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs86spc.htm
In the 89XX series of phones you will find 8961 but not 8945.
Hence this means that we do not support srst for 8945  in cme versions lower than cme/srst 8.8.
Hope this helps!
Karthik
13 Replies 13
Karthik Sivaram
Level 4
Level 4
hi,
Karthik
Thanks!  Just one follow up question:  Will 8945 register via srst to a lower than 15.2.1T ios?
Unfortunately No.
Do you have a link that goes over that?
Hope this helps!
Karthik
Thanks for the info!   I appreciate it.
Bumping the thread since I updated the original question.
Thanks!
I just haven't got the knack for finding the info I need yet.
Youssef Aoufi
Level 3
Level 3
Hi there,
I have a working CME 8.8 system using different type of IP Phones.
Everything's working fine but the 8945 phones.
The problem is that they can register , but they can't update to the french locale.
Any idea guys?
Thank you in advance
HI
Please upgrade to CME 9.0 and install the french locale.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
We upgraded to CME 9.1 and we still have the same problem, 8945 ip phones can't update to french.
Any help will be appreciated,
Many thanks
we resolved this problem by using the latest Local: CME-locale-fr_FR-French-8.8.2.5 instead of CME-locale-fr_FR-French-8.8.2.3. But we still have a problem with accented letters (é à è ù ...) that doesn't appear correctly on IP Phones 8945 !!
unfortunately Cisco TAC says that is a "BUG that has been active for some time now and affects most phones and platforms and its currently being tracked with this ID CSCuc51096 "!!
Best regards,
