upgrading firmware of one phone
techguy
Level 4
Level 4
 Hi Experts,
I want to upgrade one ip phone 7962 registered in cucm 11.5. I have done following steps.
Phone Load Name: SCCP42.9-4-2SR1-1S
Load Server: IP address of one voice gateway
This gateway is acting as tftp server. files are in flash files and telephony service is running.
tftp-server flash0:apps42.9-4-2ES9.sbn
tftp-server flash0:cnu42.9-4-2ES9.sbn
tftp-server flash:cvm42sccp.9-4-2ES9.sbn
tftp-server flash:dsp42.9-4-2ES9.sbn
tftp-server flash0:jar42sccp.9-4-2ES9.sbn
tftp-server flash0:SCCP42.9-4-2SR1-1S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
10     4637232 Feb 29 2014 19:17:38 +00:00 apps42.9-4-2ES9.sbn
11    582093 Feb 29 2014 19:20:56 +00:00 cnu42.9-4-2ES9.sbn
12     2217086 Feb 29 2014 19:31:32 +00:00 cvm42sccp.9-4-2ES9.sbn
13      364207 Feb 29 2014 18:29:26 +00:00 dsp42.9-4-2ES9.sbn
14     1763397 Feb 29 2014 18:37:28 +00:00 jar42sccp.9-4-2ES9.sbn
15         666 Feb 29 2014 18:53:22 +00:00 SCCP42.9-4-2SR1-1S.loads
16         662 Feb 29 2014 18:53:54 +00:00 term42.default.loads
17         662 Feb 7 2014 18:54:08 +00:00 term62.default.loads
telephony-service
 max-ephones 5
 max-dn 5
 ip source-address 10.1.10.100 port 2000
 load 7962 SCCP42.9-4-2SR1-1S
 max-conferences 8 gain -6
 transfer-system full-consult
 create cnf-files version-stamp 7960 Jan 27 2018 23:44:19
I am now resetting this phone from web then restarting to get upgraded but it again comes up with old firmware. Any suggestions? Many thanks.
Jaime Valencia
Debug TFTP on the router and see if it does get a request, and if it does, if it finds the file
java
if this helps, please rate
R0g22
This is for CME then and not CUCM. Do you have the correct Option 150 configured correctly to point to this router acting as TFTP server ?
Not necessarily, he specified he's using the load server option in CUCM to force the phone to use a specific TFTP for the FW, he's using that ISR to work as the TFTP holding the FW.
java
You are right Java. I bet didn't see that the first time around. My bad.
