02-24-2015 10:32 AM - edited 03-17-2019 02:06 AM
When buying the VG310 / 320 for use with CUCM 10.x is it required to have a UCL Essentials license for each analog endpoint ? Or is that included in the price/image of the VG ?
Also, is there a part-number from blackbox (or another vendor) that provides a finished RJ21/amplenol to RJ45 patchpanel for 24 ports ?
Thx,
GP
Solved! Go to Solution.
02-25-2015 09:06 PM
02-25-2015 09:21 AM
I've found the part-numbers for the amphenol patch panel & corresponding cabling. Rest the question cfr licenses ...
GP
02-25-2015 09:06 PM
02-26-2015 12:51 AM
Thanks Aman - I was afraid of that (as it prices us out of the market compared to other vendors in this specific situation). But appreciate you taking the time to post the correct link/information - +5 :)
GP
07-28-2022 10:51 AM
Hey Gert, would you mind sharing what you found for cables and patch panels?
07-28-2022 11:58 AM - edited 07-28-2022 12:00 PM
Recommend you to create your own post for your questions, that is somewhat off topic from the OP, as this is a very old post and it is apart from this marked as solved, as this would likely get you a better chance of getting the required help.
