07-16-2015 05:54 AM - edited 03-17-2019 03:39 AM
Has anyone by chance set one of these up successfully in 8.6.2 in a production environment? I have a project for a new site on an 8.6.2 cluster and need to have 7 of these. We do not have that many VG224's and can no longer buy them, but we can get the 310's.
Any help is greatly appreciated and I do know TAC will not support this in production, but we are doing an upgrade in the Fall to 10.5.2 and if I can get by till then I will.
07-16-2015 06:17 AM
I just deployed multiple VG350s in an 8.6.2 environment without any issues. I used BVIs (bridged virtual interfaces) and used SCCP as the signaling protocol. It's pretty straight forward but with 8.6.2 you will have to create the analog ports in CUCM manually. In later releases you can use BAT. Below are some useful documents.
Yosh
07-16-2015 06:26 AM
Yes the 350's are available within the drop down when you go to add a new gateway, but the 310's are not and even with the latest Device Pack would not be either.
Trying to see if anyone has actually deployed them in 8.6.2 defining them as let's say a VG224.
10-15-2015 01:44 AM
Hi Gregory
I'm hitting the same request. Wondering if you had some further feedback on this topic maybe registering VG310 as H323 gateway and building a peering with them
thanks
Marco
07-16-2015 07:41 AM
Hi Gregory,
Please check the following doc http://www.cisco.com/c/en/us/td/docs/routers/access/vg350/software/configuration/guide/vg350_scg/scgapp_platforms_ORIG.html
We had to get a refurbished VG224 as we will also waiting to upgrade call manager version. I tried to add VG310 as VG224 but the ports on call manager are not matching with ports on gateway.
10-23-2015 04:08 AM
Hi Gregory,
maybe a bit to late and you allready updatet to 10.5 but you can try to configure the VG310 with SIP dial-peers to the CUCM and use a SIP-Trunk from your CUCM 8.6 to the VG310
It wouldn't be a beautiful solution. H323 would also be possible.
Best regards
Franz
