VG310 SIP Trunk License to Non-Cisco SIP Server
Jerry Jiang
Hi there,
Currently I'm planning to setup SIP trunk between VG310(analog phones connected) and a Non-Cisco SIP Server. I'm wondering do I need to purchase any license ? Thank you in advance.
Chris Deren
Since you are connecting via SIP to non-Cisco PBX there is no licenses that need to be applied anywhere, unless your 3rd party solution requires SIP licensing as some do.
6 Replies 6
Manish Gogna
Hi Jerry,
What is the complete setup? If the VG310 is registered to CUCM then there is no license requirement for trunks on VG from cucm perspective.
Manish
Hi Manish,
I'm planning to connect analog phones to VG310 and then SIP Trunk from VG 310 to Avaya SIP Server and finally from SIP Server to Cisco 2900 Voice Gateway to PSTN via either E1 or FXO.
Hi Jerry,
From CUCM or VG310 perspective there are no license requirements for this setup.
Manish
Thanks, Manish.
Hi Jerry
were you able to do so? can you use sip trunk with this VG?
Chris Deren
