02-06-2015 08:56 AM - edited 03-17-2019 01:52 AM
Sure hope I'm missing something but can someone tell me where or how to configure a VG320 (IOS 15.4(3)M1) for SCCP to CUCM 10.5? None of the voice-port commands are present. I have the VG320 configured in CUCM as SCCP with last 10 of MAC. I also have the SCCP commands configured on the VG320.
This is the first VG320 I have configured. I have configured a few VG350's with no issue.
Dan
Solved! Go to Solution.
02-09-2015 02:49 PM
To close the thread, VG320 ships with one PVDM3-128. In this case we confirmed the PVDM3 was missing hence no voice-port configuration could be done.
02-08-2015 05:19 AM
Which voice port configuration are you referring to. You don't need to apply any configuration at the port level for sccp to work.. sample configuration is shown below
stcapp ccm-group 1
stcapp
sccp local FastEthernet0/0
sccp ccm 10.4.131.200 identifier 7815
sccp ccm 10.4.138.77 identifier 7825
sccp
sccp ccm group 1
associate ccm 7815 priority 1
associate ccm 7825 priority 2
dial-peer voice 500 pots
service stcapp
port 2/0
dial-peer voice 501 pots
service stcapp
port 2/1
02-08-2015 05:24 AM
When i build the dial-peers, I don't have a port X/Y command available for some reason. It's missing from available commands.
Dan
02-08-2015 05:47 AM
Can you send a sh version and a sh run of the gateway
02-08-2015 05:52 AM
02-08-2015 06:33 AM
Something is nor right with this device. The sh run doesn't display the available voice ports. Hence it appears as if there are no voice port on the gateway. I suggest you try and reboot the gateway and if the voice-ports still do not show up, then you may have a faulty device. Because the voice-ports do not show up, you cant assign them to any dial-peer.
02-08-2015 06:39 AM
Customer has two of them and both are showing the exact same missing voice-port configuration. Devices have been rebooted multiple times and latest IOS has been installed. These are brand new devices so I'm assuming I'm missing some new configuration. Guess I will open a TAC case.
Dan
02-08-2015 07:36 AM
It's possible the units are defective. You should at least see the voice ports in the sh run.
02-09-2015 02:49 PM
02-10-2015 02:10 PM
Thank you for the update. You would have thought my head should atleast think that we need PVDM to bring up fxs ports. Well big head that I am.. LOL!!
05-11-2016 11:17 PM
Hello Dan,
I am about to configure a Cisco VG350 for the first time. Can you please send me the sh run of a working VG350 that you have configured? I need it for reference.
Thanks!
Ram.
03-03-2019 10:38 PM
i am trying to configure first time VG 350-with 96 port, vg320 and vg310 with cuc 11.X...
please advise me if possible to configure as sip rather than sccp and mgcp..
also would be great if you share your working configuration of VG gateway 350, 320...?
thank you in advance!
