Voice and Data VLAN in same port
SMK91
Hi All,
When we using both Voice and Data VLAN in the same switch port, Can we keep the Data traffics in VLAN 1 and assign a new VLAN for Voice Traffic..?
interface GigabitEthernet x/y
switchport access vlan 1
switchport mode access
switchport voice vlan 20
Is this possible?  Please help.
9 Replies 9
Yes its possible.
for your configuration, phones will work in vlan 20 and data in 1
Response Signature
Thank you Nithin
Hi Nithin,
Can we use these same configurations with non-Cisco phones?
balaji.bandi
yes possible with the config, make sure you have Options set in DHCP for the Voice VLAN.
BB
Thank you, Balaji.
What do you mean by Option set in? Is that 150 or 66? Is that necessary one?
George Sotiropoulos
Yes, this is possible. You may find the following post on the Community useful:
https://community.cisco.com/t5/networking-documents/sample-configuration-for-voice-and-data-deployment-on-a-switch/ta-p/3123513
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Thank you, George.
Hi George,
You can find quite  some info in Community concerning this subject, have a look on this one:
https://community.cisco.com/t5/ip-telephony-and-phones/non-cisco-voip-phones/td-p/2800328
