Hello, Is there any Cisco internal or external tool to get serial number from MAC address? BR,Krisztian
Hello, Im struggling with QoS configuration on my local network (check attached file). I made basic configuration. There is vlan from switch card on router to phones and WAN port to PC. Everything works fine. Then I establish connection between route...
Hi We downloaded visio stencil from link below (Sub file in > Unified Computing System and HyperFlex Systems (HCI) (ZIP - 73 MB) 16/Jul/2020) https://www.cisco.com/c/en/us/products/visio-stencil-listing.html We found UCS C220 M5 but equipment m...
I am trying to confirm a minor inconvenience that was brought up to me as expected behavior... When getting off a call on a secondary line and putting the handset down (or ending the call by any other means) - the 8800 series phone seems to default b...
Dear Team ,we are using jabber client through expressway edge . everything is working fine for jabber users to access internally and externally.security team refused to expose Expressway edge to internet and instead we have to use Airwatch to connect...
This was installed by a previous company and are replacing it with Teams, however, I need some BASIC reports out of it, which I cannot seem to find easily. All I want to know if how many incoming calls we get to our main number for a date range. I ...
Hello Dear,I have 2 line for outside calling.1. IPTSP2. PSTN.I need to configure Route Patterns as below :Format 1: For all call going to IPTSP to direct (Patterns .!) is working.Format 2 : Need to all call going to PSTN before dialing (Patterns 9.) ...
Hi,I am facing issues with call forward in CUCM 11.5. In H323 gateway page i have changed calling party selection (outbound calls) to First Redirect Number (External). Calls coming from PSTN are forwarding to mobile (PSTN) if call is not answered.How...
Can I use any POE switches for connecting Cisco unified IP phone 8800 series?Or Is there a certain type of POE switches available to connect the Cisco IP phone 8841/8851?Can I use Cisco Business POE switches (CBS250/350) for connecting Cisco unified ...
Hi ,I am getting this message everyday.Your voice mailbox has exceeded the quota warning threshold specified by your administrator. Current Usage: 15.96 MBQuota Warning Threshold: 11.44 MBQuota Size Limit: 14.06 MB Please reduce your voice mailbox si...
Hello, We have Expressway C & E servers and the Cisco Jabber MRA feature has been deployed for all the employees. All of our users have laptop and they use Jabber on their windows and on their Android phones. Since MRA is allowed, they are able to r...
Hello Everyone.Hope you are doing well. I have configure dial peer in to the cisco cube. Voip dial peer working fine, but Pots dial peer is not working. Can you help to me..!!!dial-peer voice 1 voipdescription ***Inbound LAN side dial-peer***translat...
Good Morning ColleaguesI hope you are doing good and safe. May i know if CISCO888G-K9 - which has 3G interface - can be configured for Voice over its 3G interface (send and receive voice calls over 3G interface and be able to add 3G as dialpeer simil...
Hello Dear,I need to help the configuration.I have configure PSTN pots configuration.Incoming call is not coming. Also cant configure outgoing dial peer.Below as my configuration .Note: I am new in this filed. Please help the the configuration. voice...
Hollow community. My users which are to be installed on cucm have firstName, lastName and staffNumber. I'm looking for a way to anonymised the userId. can anyone share any strategies that they've used please? The purpose is to limit the storage of ...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
