Voice/Data T1/E1 Crossover back-to-back Cable DIY or Buy?
David_Mitchell
Hi All,
I am trying to build a Voice lab and it's starting to cost a fortune for the kit.
I have seen a T1/E1 cross over cable on the link below and I need two of these from my set up
http://www.ebay.co.uk/itm/UTP-Voice-data-T1-E1-Cross-Crossover-back-to-back-Cable-Cisco-Voice-CCIE-CCVP-/230771200798#ht_1364wt_1231
Could anyone advise if this is a special type of UTP cable or is this standard Ethernet cable with RJ45 connectors just with a different pinout configuration?
If it's just the order of the wires in the cable I have a reel of UTP and a crimping tool I can use to make my own
Your help is appreciated as always
Cheers,
David
2 Accepted Solutions
Ayodeji Okanlawon
T1/E1 cross over cable is very easy. You should make yours and dont waste your money buying ready made..
The pin out you need is this..
1----------->4
2----------->5
4----------->1
5----------->2
The images below shows you the pin out configuration
https://www.google.co.uk/search?q=t1/e1+crossover+cable&tbm=isch&tbo=u&source=univ&sa=X&ei=EnRqUrmdK8GW0AWKsIGYDw&ved=0CD0QsAQ&biw=1600&bih=799
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Rob Huffman
Ayodeji Okanlawon
1----------->4
2----------->5
4----------->1
5----------->2
Rob Huffman
Hi David,
+5 to my friend Deji here You ROCK my friend!!
http://www.t-radtalk.com/howto/how_to_make_a_t1_cross_over.htm
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a3f09.shtml
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Hi David,
You can also refer the link
https://supportforums.cisco.com/docs/DOC-9474
regds,
aman
