01-27-2012 01:59 AM - edited 03-16-2019 09:14 AM
Hi All,
I'm not able to find VWIC3-4MFT-T1/E1 option in my call manager while configuring MGCP gateway.
Router Model : Cisco 2951
CUCM Version : 7.1.3.32900-4.
Kindly suggest me a solution.
Loga S
CCNP R&S,CCNA Voice.
01-27-2012 02:39 AM
hi Loganathan,
Minimum Cisco Unified Communications Manager Release required for VWIC3-4MFT-T1/E1 is 7.1.5 or 8.0.2
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Hope this helps!
Karthik
01-27-2012 02:41 AM
Hi Karthik,
You mean to say like,i have to upgrade my Call Manager version.Right??
If so does it require a system restart???
Loga S
01-27-2012 02:50 AM
it requires CUCM version 7.1.5 or 8.X. please find the below link for reference
Baskaran.M
01-27-2012 03:32 AM
Use H.323 os SIP instead of MGCP.
Beside being indipendant from the hardware used, you will enjoy better stability, easier configuration, and a much richer set of features with no protocol-derived limitations.
06-14-2012 08:29 PM
I'm having exactly the same issue with a 3945, but do have version 7.1.5.2000.6 - which should support this VWIC.
06-14-2012 08:57 PM
Upgrade to latest CUCM 7.1.5 release, it wil resolve the issue.
Ronak patel
Rate helpful posts.
