Want to forward the incoming call to Mobile number or international call
mohammad saeed
Level 5
Level 5
Hi Guys,
I have CUCM 8.5 with SIP trunk from SP and I have CUBE as well.
I want if some one call internal extension and there is no answer then the call forward to mobile number or international Call, Can  I configure this option inside CUCM? DO I need to do something in CUBE?
If there is any configuration document can help?
Thanks for all
Mohammad Saeed
26 Replies 26
You can do it  from from line page Call Forward and Call Pickup Settings
Example
  • Forward Busy Internal&External :- i forward it to my Mobile number, forwarding CSS i kept GSM.
  • Forward No Answer Internal& External :- i forward to an international number, forwarding CSS i kept international
1.PNGMost ISP drop the call if you send ANI other than the DID block and they do this for billing purpose. if the forwarded call use ANI other than your DID block, ISP will drop it.
so to avoid the above issue ,on gateway configuration page Call Routing Information - Outbound Calls i use last redirect/First redirect(depend on scenarios).
Response Signature
Hi Nethin,
I tried it but gives me invalid number when no answer forward!
Did you configured correct CSS for forwarding ? Does the forwarded call Hit gateway ?
Response Signature
Yes I have Mobile CSS and I am using it to make a mobile call and it works with me. Is it enough? or need to do another else?
Yes it hits the GW and I see this error "Address incomplete"
Received:
SIP/2.0 484 Address Incomplete
Via: SIP/2.0/UDP 10.10.10.10:5060;branch=11111111
Record-Route: <sip:10.200.7.157:5060;transport=udp;lr>
Call-ID: 1111-11111-1111-1111@20.20.20.20
To: <sip:0119874562@10.10.10.10>;tag=sbc0806bskphcu2
CSeq: 101 INVITE
Reason: Q.850;cause=28;text="address incomplete"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
If supported by your service provider add a Diversion header to the outbound invite. Quite often that is required for the SP to accept the call if it comes from a out of DDI range number.
Response Signature
I have this debug sip call ourput:
VG1#
Mar 26 13:30:24.505: //4378287/F11D86000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2BD06008
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 5386152
Called Number : 0112359535
Source IP Address (Sig 10.10.10.10
Destn SIP Req Addr:Port : 20.20.20.20:5060
Destn SIP Resp Addr:Port : 20.20.20.20:5060
Destination Name : 10.200.7.157
Mar 26 13:30:24.505: //4378287/F11D86000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.10.10.10
Source IP Port (Media): 29956
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 28
Disconnect Cause (SIP) : 484
Mar 26 13:30:24.505: //4378286/F11D86000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BCCDCA8
Calling Number : 6152
Source IP Address (Sig 10.60.2.12
Destn SIP Req Addr:Port : 10.60.2.10:5060
Destn SIP Resp Addr:Port : 10.60.2.10:5060
Destination Name : 10.60.2.10
Mar 26 13:30:24.505: //4378286/F11D86000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 10.60.2.12
Source IP Port (Media): 30540
Destn IP Address (Media): 10.60.2.11
Destn IP Port (Media): 26062
Mar 26 13:30:24.509: //4378286/F11D86000000/SIP/Call/sipSPICallInfo:
Mar 26 13:30:24.509: //4378285/4122E54DB75A/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BCD9088
Calling Number : 566601998
Called Number : 6152
Mar 26 13:30:24.509: //4378285/4122E54DB75A/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 19476
Mar 26 13:30:24.517: //4378288/4122E54DB75A/SIP/Call/sipSPICallInfo:
Destn SIP Req Addr:Port : 10.60.2.11:5060
Destn SIP Resp Addr:Port : 10.60.2.11:5060
Destination Name : 10.60.2.11
Mar 26 13:30:24.517: //4378288/4122E54DB75A/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 29734
Disconnect Cause (CC) : 1
Disconnect Cause (SIP) : 404
Mar 26 13:30:24.553: //4378284/4122E54DB75A/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BCE9E58
Called Number : 5386152
Destination Name : 20.20.20.20
Mar 26 13:30:24.553: //4378284/4122E54DB75A/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Dtmf-relay Payload : 116 (tx), 116 (rx)
Source IP Port (Media): 16858
Destn IP Address (Media): 20.20.20.20
Destn IP Port (Media): 36482
ITSPs vary wildly in their requirements for forwarded calls, very little consistency in which headers are required and what these headers should contain.  Can you post up SIP message debugs "debug ccsip mess"?  But before that, enable diversion headers on the CUCM to CUBE SIP trunk as suggested.
Just so we're clear on number formats, can you also post up example Invite for a working inbound call, and a working outbound.
I enabled in CUCM:
Redirecting Diversion Header Delivery - Inbound
Redirecting Diversion Header Delivery - Outbound
That looks like an excerpt from a SIP Profile on the CUBE in which case you're leaving us behind.  Can you post an example of the outbound Invite as it is sent without the SIP Profile applied, and explain which headers you want to change and what changes are needed?
FYI typically if an ISTP requires the Diversion header, you want "From" to be the original inbound caller, "To" and the uri itself the redirected destination (the number you're forwarding to) and the number in Diversion should be one of your inbound DDIs.
However ITSP requirement differ so this is all guesswork especially as you haven't named the ISTP involved.  What I described is what AT&T want in the US.  But that would not be correct for example for Gamma in the UK who use PAI instead.
I made a debug for ccsip message:
Mar 26 14:44:56.701: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.189.2.238:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKfoa2utoc74oedhttd4uhkoucaT32265
Call-ID: isbcpee2hffcotfd4dp2724dfaf44fhuppus@SoftX3000
To: <sip:10.189.2.238>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Mar 26 14:44:56.705: //4378756/AADB20B4B9EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.189.2.238>;tag=C09F45CC-1AB
Date: Fri, 26 Mar 2021 14:44:56 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 6269 2518 IN IP4 10.189.2.238
s=SIP Call
c=IN IP4 10.189.2.238
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
Mar 26 14:44:57.885: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5386152@10.189.2.238;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKscuhkfb7o224e4khfb2fof772T07451
Call-ID: isbctooaceu7ehshtecphokaca7dcb7sftte@SoftX3000
From: <sip:566601998@10.189.2.238;user=phone>;tag=sbc0807fc7aeppe-CC-57
To: <sip:5386152@10.189.2.238;user=phone>
CSeq: 1 INVITE
Max-Forwards: 69
Contact: <sip:566601998@10.200.7.157:5060;user=phone>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
User-Agent: Huawei SoftX3000 V300R010
Supported: 100rel
Content-Length: 319
v=0
o=- 31840388 31840388 IN IP4 10.200.7.157
s=SBC call
c=IN IP4 10.200.7.157
t=0 0
m=audio 41598 RTP/AVP 8 102 102 0 18 116
a=rtpmap:8 PCMA/8000
a=rtpmap:102 AMR/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:116 telephone-event/8000
a=fmtp:116 0-15
a=fmtp:18 annexb=yes
Mar 26 14:44:57.889: //4378757/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Fri, 26 Mar 2021 14:44:57 GMT
CSeq: 1 INVITE
Content-Length: 0
Mar 26 14:44:57.889: //4378758/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:6152@10.60.2.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.60.2.12:5060;branch=z9hG4bK5BFCA44D
Remote-Party-ID: <sip:566601998@10.60.2.12>;party=calling;screen=no;privacy=off
To: <sip:6152@10.60.2.10>
Call-ID: AB90661E-8D7811EB-B9F5DA71-29E28895@10.60.2.12
Min-SE: 1800
Cisco-Guid: 2878327133-2373456363-3119503985-0702711957
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1616769897
Contact: <sip:566601998@10.60.2.12:5060>
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 290
v=0
o=CiscoSystemsSIP-GW-UserAgent 3745 5216 IN IP4 10.60.2.12
s=SIP Call
c=IN IP4 10.60.2.12
t=0 0
m=audio 19808 RTP/AVP 8 100 101
c=IN IP4 10.60.2.12
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Mar 26 14:44:57.893: //4378758/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Fri, 26 Mar 2021 14:41:35 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Mar 26 14:44:57.901: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0112359535@10.60.2.12:5060 SIP/2.0
Via: SIP/2.0/UDP 10.60.2.10:5060;branch=z9hG4bK1e3146a219846
From: <sip:6152@10.60.2.10>;tag=190187~89711f2a-613c-4c32-92da-cd0f7d30bcbc-20761971
To: <sip:0112359535@10.60.2.12>
Call-ID: 5bd3bf00-5d1f29f-1a305-a023c0a@10.60.2.10
Min-SE: 1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 1540603648-0000065536-0000007571-0167918602
Session-Expires: 1800
Diversion: <sip:6152@10.60.2.10>;reason=unconditional;privacy=off;screen=yes
P-Asserted-Identity: <sip:6152@10.60.2.10>
Remote-Party-ID: <sip:6152@10.60.2.10>;party=calling;screen=yes;privacy=off
Contact: <sip:6152@10.60.2.10:5060>
Max-Forwards: 67
Content-Length: 210
v=0
o=CiscoSystemsCCM-SIP 190187 1 IN IP4 10.60.2.10
s=SIP Call
c=IN IP4 10.60.2.11
t=0 0
m=audio 26128 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
Mar 26 14:44:57.909: //4378759/5BD3BF000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Mar 26 14:44:57.909: //4378760/5BD3BF000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0112359535@10.200.7.157:5060 SIP/2.0
Via: SIP/2.0/UDP 10.189.2.238:5060;branch=z9hG4bK5BFCB3A0
Remote-Party-ID: <sip:5386152@10.189.2.238>;party=calling;screen=yes;privacy=off
To: <sip:0112359535@10.200.7.157>
Call-ID: AB9372E6-8D7811EB-B9FBDA71-29E28895@10.189.2.238
Min-SE: 1800
CSeq: 101 INVITE
Contact: <sip:5386152@10.189.2.238:5060>
Expires: 180
Max-Forwards: 66
Diversion: <sip:6152@10.60.2.10>;privacy=off;reason=unconditional;screen=yes
Content-Length: 295
v=0
o=CiscoSystemsSIP-GW-UserAgent 3756 601 IN IP4 10.189.2.238
s=SIP Call
t=0 0
m=audio 16682 RTP/AVP 8 100 101
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Mar 26 14:44:57.957: //4378760/5BD3BF000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Mar 26 14:44:58.021: //4378760/5BD3BF000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:0112359535@10.200.7.157>;tag=sbc0802ud7cfab4
CSeq: 101 INVITE
Content-Length: 0
Mar 26 14:44:58.025: //4378760/5BD3BF000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BCAC108
Source IP Address (Sig 10.189.2.238
Destn SIP Req Addr:Port : 10.200.7.157:5060
Destn SIP Resp Addr:Port : 10.200.7.157:5060
Mar 26 14:44:58.025: //4378760/5BD3BF000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 10.189.2.238
Source IP Port (Media): 16682
Mar 26 14:44:58.025: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0112359535@10.200.7.157:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 14:44:58.025: //4378759/5BD3BF000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:0112359535@10.60.2.12>;tag=C09F4AF8-8CB
CSeq: 101 INVITE
Content-Length: 0
Received:
ACK sip:0112359535@10.60.2.12:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 14:44:58.025: //4378759/5BD3BF000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BD16DD8
Mar 26 14:44:58.025: //4378759/5BD3BF000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 17664
Destn IP Port (Media): 26128
Mar 26 14:44:58.029: //4378758/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:6152@10.60.2.10>;tag=190186~89711f2a-613c-4c32-92da-cd0f7d30bcbc-20761968
CSeq: 101 INVITE
Content-Length: 0
Mar 26 14:44:58.029: //4378758/AB8FC95DB9EF/SIP/Call/sipSPICallInfo:
Mar 26 14:44:58.029: //4378758/AB8FC95DB9EF/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 19808
Mar 26 14:44:58.033: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:6152@10.60.2.10:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 14:44:58.033: //4378761/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:6152@10.60.2.11:5060 SIP/2.0
Via: SIP/2.0/UDP 10.60.2.12:5060;branch=z9hG4bK5BFCC16B3
To: <sip:6152@10.60.2.11>
Date: Fri, 26 Mar 2021 14:44:58 GMT
Call-ID: ABA66024-8D7811EB-B9FDDA71-29E28895@10.60.2.12
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1616769898
Expires: 180
Max-Forwards: 68
Content-Length: 290
v=0
o=CiscoSystemsSIP-GW-UserAgent 9490 9452 IN IP4 10.60.2.12
s=SIP Call
c=IN IP4 10.60.2.12
t=0 0
m=audio 19592 RTP/AVP 8 100 101
c=IN IP4 10.60.2.12
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Mar 26 14:44:58.037: //4378761/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Fri, 26 Mar 2021 07:26:23 GMT
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 404 Not Found
To: <sip:6152@10.60.2.11>;tag=1822862~89711f2a-613c-4c32-92da-cd0f7d30bcbc-33963604
CSeq: 101 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Mar 26 14:44:58.037: //4378761/AB8FC95DB9EF/SIP/Call/sipSPICallInfo:
Mar 26 14:44:58.037: //4378761/AB8FC95DB9EF/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 19592
Mar 26 14:44:58.041: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:6152@10.60.2.11:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 26 14:44:58.041: //4378757/AB8FC95DB9EF/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:5386152@10.189.2.238;user=phone>;tag=C09F4B04-1D44
CSeq: 1 INVITE
Content-Length: 0
Mar 26 14:44:58.073: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5386152@10.189.2.238;user=phone SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Mar 26 14:44:58.073: //4378757/AB8FC95DB9EF/SIP/Call/sipSPICallInfo:
Mar 26 14:44:58.073: //4378757/AB8FC95DB9EF/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 32042
Destn IP Address (Media): 10.200.7.157
Destn IP Port (Media): 41598
Mar 26 14:45:03.953: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.60.2.12:5060 SIP/2.0
Via: SIP/2.0/UDP 10.60.2.10:5060;branch=z9hG4bK1e3151e49a20b
To: <sip:10.60.2.12>
Date: Fri, 26 Mar 2021 14:41:41 GMT
Call-ID: 5f674600-5d1f2a5-1a306-a023c0a@10.60.2.10
CSeq: 101 OPTIONS
Contact: <sip:10.60.2.10:5060>
Max-Forwards: 0
Content-Length: 0
Mar 26 14:45:03.953: //4378762/AF2DAD3BB9FE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.60.2.12>;tag=C09F6220-2432
Date: Fri, 26 Mar 2021 14:45:03 GMT
CSeq: 101 OPTIONS
Content-Length: 161
v=0
o=CiscoSystemsSIP-GW-UserAgent 5526 2491 IN IP4 10.60.2.12
s=SIP Call
c=IN IP4 10.60.2.12
t=0 0
c=IN IP4 10.60.2.12
I don't have SIP profile applied in CUBE only what applied is in the diversion header in CUCM for inbound and outbound until this moment.
At a guess, the Diversion header needs to have your full external number.  Currently you're sending ...
I suspect they want to see ..
Diversion: <sip:5386152@10.60.2.10>;privacy=off;reason=unconditional;screen=yes
Although they may have other requirements.
Is your called number in the correct format?  For example the highlighted number here, are they the same as in a working normal outbound call?
Difficult to be more specific without knowing the country and the carrier.  I was trying to guess but I can't off the top of my head think of a country with seven digit national numbers starting with "5".
Yes this number is 0112359535 is correct when I dial it from IP phone "90112359535" it dials. The SP is STC in Saudi Arabia
