01-23-2018 10:48 AM - edited 03-17-2019 12:01 PM
If the device CSS is used when making calls and the specific forwarding CSS is used when forwarding calls. What is the directory number CSS used for?
Solved! Go to Solution.
01-23-2018 11:00 AM
Hi -
There is a lot on this topic in this forum - you can do a search. Also, great information on this in the SRND - look at the dial plan - Calling Privileges in Unified CM section
Les
01-23-2018 11:00 AM
Hi -
Les
01-23-2018 12:20 PM
I did a search, but I assume the terms I was using were not coinciding with the terms that would have got me the answer.
From my short amount of testing after reading the SRND.
When placing a call the device-CSS and the line-CSS are both used. This allows you to expand your total calling search space.
Thanks for the quick response.
01-23-2018 11:01 AM
You could potentially have multiple DN's assigned to a single phone, each requiring a unique CSS.
