Network Management
Labels
adquirí 3 router, lo configure a través de consola, funciono muy bien como repetidor Wi Fi, pasado unos años de pronto comensaron a parpadear las luces de verde a naranja y a rojo y se perdio el Wi Fi. los resetee volvi a configuralo pero con la wi f...
I teach Netacad CCNA level courses and a problem we run into is with 4 or 5 courses sharing the same hardware, students will use dumb passwords, forget them, & then we have to do the annoying romon fix.I researched setting up an applet that would del...
HelloI came across weird situation that is I cannot login to firepower 1010 using console. When I type in my username and hit enter it prints out "Login incorrect" 20 times and then "Login timed out after 60 secodns". It stopped working properly afte...
zoahfan by • Community Member
  • 181 Views
  • 2 replies
Hello,As a senior networking student, I am currently planning my graduation project and would greatly appreciate your guidance. I am looking for a unique and innovative project idea that combines networking, security, and, if possible, some programmi...
fx_33 by • Visitor
  • 4319 Views
  • 8 replies
     I'm replacing two 2901 routers with newer 4331 routers both running IOS-XE 17.12.07b.  The two routers are at two different sites with two different internet service providers.  On both routers, I have the "ip address dhcp" on my WAN interface, ...
rtw77 by • Community Member
  • 733 Views
  • 6 replies
