Netflow problem with Prime Infrastructure
Mason Tu
I am using Prime Infrastructure 1.2 eval version.(100 devices and 150 interfaces limit)
I was hoping to send netflow data from Nexus 7010 and 3750X to PI.
So I add them manually and set up configuration for netflow.
After that, I can't see anything about netflow in [Operate]->[Performance]->[Service Assurance]
It shows no data available.
I look up in the user guide to figure out the problem.
Then I use [Configuration Templates] to deploy netflow config again.
The result is the same.
Can anyone with experience using netflow function in PI 1.2 could tell me where did I miss?
Thanks in advanced.
13 Replies 13
Pandian G K
Hi Mason Tu,
Can you check any access list blocking your switches from sending data to PI
HTH ,
Pandian.
Hi Pandian,
Thanks for your reply, but we don't have any access-list configuration on the switch.
And this is a test lab , there is no firewall as well.
I try to ping from switch to PI, it's fine.
Dear Mason,
Did you ever find a solution for this problem?
Please advise,
Moustafa
Hi Moustafa,
I don't have any solution for this problem.
Do you meet the same problem?
Carl Dragert
Hi Moustafa
I have the same problem. Is your prime server connected to a Nexus switchport?
May be My problem startes when I moved the prime server from a 3560x to a Nexus. It is a wild gues, but I will try moving it back.
Sent from Cisco Technical Support Android App
netdood
Any resolutions?
Same problem no netflow data.  Netflow data is being exported fine to Solarwinds and sh ip flow export shows many flows being exported.
Check the port assignments. We had an issue with this during Eval and it was due to ports.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
Agree with Christopher, check the destination port setting.
Another concern point is the version of 3750X module has to be compatible with 3750X itself.
If the version of these two are mismatch, no netflow can be exported.
The port is 9991 for Prime right?  Here is my 6509 netflow config which works for other reporting software.  I've just added my prime vm appliance IP with port 9991.  I see a few netflows in data sources but no TX or RX data for the interface ( see attached pics ).
mls aging long 64
mls aging normal 64
mls netflow interface
mls flow ip interface-full
mls nde sender version 5
ip flow-export source VlanX
ip flow-export version 5
ip flow-export destination PRIME_IP 9991
ip flow-export destination SOLARWINDS_IP 2055
interface Port-channelX
ip address IP
ip flow ingress
ip flow egress
ip pim sparse-mode
end
6509#sh ip flow export
Flow export v5 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       MyIP (VlanX)
    Source(2)       MyIP (VlanX)
    Destination(1)  PRIME_IP (9991)
    Destination(2)  SOLARWINDS_IP (2055)
  Version 5 flow records
  23615010 flows exported in 1332989 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
  0 export packets were dropped enqueuing for the RP
  0 export packets were dropped due to IPC rate limiting
  0 export packets were dropped due to Card not being able to export
Mason,
Here are a working Netflow configuration for Nexus 7K switch:
!Command: show running-config netflow
!Time: Tue Jul 23 11:26:40 2013
version 6.1(3)
feature netflow
flow timeout active 120
flow timeout inactive 32
flow timeout fast 32 threshold 100
flow timeout session
flow timeout aggressive threshold 75
flow exporter EXP1
  destination 192.168.250.249
  transport udp 9991
  source Vlan998
  version 9
flow record REC1
  match ipv4 source address
  match ipv4 destination address
  match transport source-port
  match transport destination-port
  collect routing forwarding-status
  collect transport tcp flags
  collect counter bytes
  collect counter packets
  collect timestamp sys-uptime first
  collect timestamp sys-uptime last
flow monitor MON1_input
  record netflow ipv4 original-input
  exporter EXP1
flow monitor MON1_output
  record netflow ipv4 original-output
  exporter EXP1
interface Vlan2
  ip flow monitor MON1_input input
  ip flow monitor MON1_output output
interface Ethernet4/8
I hope this can help you.
Which cards and fabric are you using? What version of NX-OS are you using? You may be running into an issue with what the Nexus will actually support with regards to Netflow.
I don't have a Nexus, I have Catalyst 6509 and 3750 mostly.
My reply was directed to the original poster... who does have a Nexus.  If you have a separate issue with a separate product, it might be best to start your own thread?
