Bookmark
Subscribe
1817
Syslog Analyzer and RME4.0.5
paul.pink
I checked previous discussion regarding this topic and was unable to find a solution.  My syslog analyzer was working at one point, but now it has stopped and I can not get it back to a working condition. It appears the Analyzer is running, but not registering with the collector:
RME displays zero messages received by syslog collector
Syslog collector status always returns the following but is running
SLCA0132: Collector Status is currently not available.
Check whether the SyslogAnalyzer process is running normally.
        Process= SyslogCollector
        State  = Program started - No mgt msgs received
        Pid    = 4452
        RC     = 0
        Signo  = 0
        Start  = 7/12/2010 12:27:19 PM
        Stop   = Not applicable
        Core   = Not applicable
        Info   = Server started by admin request
     Process= jrm
        State  = Running normally
        Pid    = 5812
        RC     = 0
        Signo  = 0
        Start  = 7/12/2010 12:27:40 PM
        Process= CTMJrmServer
        Pid    = 9824
        RC     = 0
        Signo  = 0
        Start  = 7/12/2010 12:31:02 PM
        Info   = CTMJrmServer started.
        Process= SyslogAnalyzer
        Pid    = 4564
        RC     = 0
        Signo  = 0
        Start  = 7/12/2010 12:32:00 PM
SYSLOG Collector.log
SyslogCollector - [Thread: main] INFO , 12 Jul 2010 12:27:19,703, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 12 Jul 2010 12:27:19,703, System Initialized.
SyslogCollector - [Thread: main] INFO , 12 Jul 2010 12:27:19,917, Subscriber list is empty!
SyslogCollector - [Thread: main] INFO , 12 Jul 2010 12:27:26,247, Service started...
Tried to subscribe to the collector - received the folowing message.
SLCA0126: Could not subscribe to the Collector.
1.Check whether the collector is running.
2.Make sure that SSL certificates are imported/exported correctly and process restarted.
3.Check whether the Certificates exported/imported are valid and have not expired.
4.Check whether SyslogAnalyzer process is running.
Any help  would be appreciated.
Joe Clarke
You are running a very old version of RME.  You should consider upgrading to RME 4.0.6 at least.
Shutdown the SyslogCollector and SyslogAnalyzer daemons.  Empty out the contents of NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/sa/data/collectors.dat and NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/filters.dat.  Then restart both daemons, and see if the subscription occurs.  Note: due to a bug in your version of RME, this may take a long time to sync if you have numerous automated actions configured.
9 Replies 9
Joe Clarke
Thanks for the recommendatin, but no go...
Post the output of "netstat -a -n -o -b" with both the SyslogAnalyzer and SyslogCollector daemons running.
Joseph,
Attached is a copy of the requested output.
Joe,
I am going to have to say that what you suggested may have worked.  I just started to receive tons of emails of old messages.
As I said, you may be seeing an old bug where it can take a LONG time for SyslogAnalyzer to fully initialize.  That's why an upgrade to RME 4.0.6 would be a good thing to do.
Hi Joseph Clarke,
I am also having a problem with Syslog wherein some devices cannot generate Syslog report. I have already upgraded to RME 4.0.6 but I still have the same problem. What do you suggest that I check?
Thank you
Start a new thread for your issue.
I already created a thread for it. I really need your help. Please see link below:
https://supportforums.cisco.com/thread/2029602?tstart=0
Thanks.
