DHCP relay on Nexus 7004 "ERROR: Hardware programming failed"
jbulloch
`Hello All,
I've recently been introduced to a setup with a Nexus 7004 chassis running as interconnect to the orgs's servers. The Nexus device then connects back to the core. There are multiple SVI's setup on a primary VDC. These have historically been all static assigned, but now there is need for DHCP on few.  I've tried to enable as i would expect it to work..
feature dhcp
ip dhcp relay
int <svi>
ip dhcp relay address x.x.x.x
But i receive the following in reponse: ERROR: Hardware programming failed. Reason: DHCP HW programing failed.
I've turned up a bug report about this issue occuring if you have too many helpers set, but at this point i have none. Has anyone encountered this before?
Ruben Cocheno
@jbulloch
check this https://www.cisco.com/c/en/us/support/docs/routers/7000-series-routers/116151-problemsolution-product-00.html
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
