Network Management
Labels
     I'm replacing two 2901 routers with newer 4331 routers both running IOS-XE 17.12.07b.  The two routers are at two different sites with two different internet service providers.  On both routers, I have the "ip address dhcp" on my WAN interface, ...
rtw77 by Community Member
  • 470 Views
  • 6 replies
The following password is configured on the Catalyst switch.Is my understanding of the command to change this password correct?<Current Configuration>enable secret 8 *********username admin secret 8 *********<Command to Change>enable algorithm-type s...
CHISHIUNG by Level 3
  • 108 Views
  • 1 replies
I have posted a similar issue before but I failed to give all of the needed details.  In short, I have ATAs that work in one client office but not another.  I have an IT company that says a firewall cannot cause any errors on an ata.   Everywhere I l...
BLB2187 by Level 1
  • 269 Views
  • 2 replies
Hi,I have been following the steps in this document (Cisco IOS XR Programmability Configuration Guide for ASR 9000 Series Router - Using Data Models [Cisco ASR 9000 Series Aggregation Services Routers] - Cisco)I copied and pasted configuration I push...
jameslee_0-1721277452208.png jameslee_1-1721277512854.png jameslee_2-1721277512856.png
jameslee by Visitor
  • 2512 Views
  • 7 replies
Is it possible to configure EEM to execute an action whenever any one of multiple syslog messages matches a pattern? I would like to know if it is possible to write syslog patterns using an "OR" condition.
  • 209 Views
  • 1 replies
We are not using camera and sensors in our environment. Organization->Firmware upgrades->Schedule upgrades-Any status (critical).I am getting all are related to camera and Sensors. I dont wish to see this details in the path Organization->Firmware up...
Annis by Community Member
  • 237 Views
  • 1 replies
  • 1 Helpful votes
