Resolved! TCC2P?s CLI on ONS 15454
Is there any possibility to set up the node ip address, mask and default gateway by the CLI command on the TCC2P card.
I have a 15305 requirement to support DS3 to STM-1 conversion but my timing source is a T1 while the 15305 requires an E1. Any suggestions on how to resolve this? Any T1 to E1 timing conversion boxes out there?
Hi!I am new to the ONS 15454 MSTP and wondering I got a coula questions1. What's the difference between OCHNC and OCHCC? 2. Is it comparable to the patch command in 15540/15530? 3. And in what configuration would you use OCHNC and OCHCC?I just deploy...
Hi,Can we configure APS between two STM-1 module in same 7206VXR router ?Please let know.Thanks!Kam
Does anyone know where I can find specific steps on building an OC3 cicuit in the 15454 node on a UPSR and BLSR ring? Its taking too long to sift thru all of the manuals and data.
Hello,How to delete "Protect version" of TCC sw on ONS15454?Because just noticing "MEM-LOW" alarm to active TCC card.Btw, is there any concern if deleting prot. sw version ?Ricky
I am trying to clear PM stats on a DS3XM12 card and I keep getting the EID-3222 message "could not clear stats". I am on REL 7.0.0. What can I do to resolve this??
I have a client that Single mode fiber running from point A to point B, and Multi mode Fiber running from point B to point C. They want to run a Gibabit network from point A to point C. If we connect the two fiber runs with a Single Mode to Multi Mod...
I have a 6509 (distribution, running 12.2(17d)SXB5) and a 6506 (core, running 12.2(17d)SXB1) device that both show Giant counts incrementing. Wanted to know what is an acceptable percentage of Giant packets, and any tips for determining the cause (ca...
I've always logged into our 15454 by the IP. However we just bought out another co and need CTM to access them. Where can I download a currentl ver??
I need to upgrade a 15327 shelf to a 15454 shelf. My ring is a 3 node BLSR ring with one 15454 and 2 15327s running on 4.14 software. The new 15454 will likely have a newer revision software. Would that cause any problems? I plan to add the new 1...
I'd like to know the experiences of anyone who has upgraded to SW version 8.0 on ONS 15454 SONET nodes. I'm trying to decide whether to use the tried-and-true 7.2.2 load or go for 8.0, which doesn't have any maintenance revs out yet. I have to do s...
Has anyone had any luck accessing CTC 4.1.6 through Windows Vista. I have installed Java runtime 1.3.1_02, matching my JRE on another management workstation (running XP). Generally I immediately told that IE has an error and it closes. Occasionall...
Hi folks,Im new to the board so I just want to first say hello and tell a little about myself. Im 35 and working in the Northern Va DC area. I was a Tech Controller in the Airforce for 8 years the a Dial Access installer for 3 years at UUNET followed...
Subject | Author | Posted |
10-07-2024 12:40 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
