11-09-2006 08:14 AM - edited 03-13-2019 03:43 PM
If I forward all my calls from my phone A to my colleage phone B, a caller receive always the voicemail from my phone A, but we need that callers receive voicemail from phone B. We need this situation for our reception scenario. Is there any parameter to change?
Marco
11-09-2006 11:22 AM
Hi Marco,
This is a question that comes up all the time and unfortunately if you are using Unity or Avaya voicemail this is working as expected.There is hope though :)
Have a look at Michaels excellent posts, there is a fix on the horizon for this exact problem in (Unity 5.0),(ECSBU Test Engineer, CISCO SYSTEMS )
"The situation you describe here (getting Unity to recognize the last forwarding station rather than the first forwarding station), will be a system-wide option added to Unity 5.0. There is not a way to do this with a configuration setting on earlier versions of Unity. I'm not aware of any CallManager settings that will address this issue either."
"We use the OriginalCalledParty and OriginalCdpnRedirectReason fields in SCCP StationCallInfo message from CallManager. The feature in Unity 5.0 will allow admin to configure Unity to look at LastRedirectingParty and LastRedirectingReason fields instead, on a system-wide basis."
From this recent thread;
Also, here is another reference to this exact question with an answer from the Unity Guru Jeff Lindborg;
Hope this helps!
Rob
Please remember to rate helpful posts........
11-09-2006 12:11 PM
Hi Marco,
There is workaround if you are using CallManager 3.3 or above, if you create a CTI Route point, or we can also play with Unity's Routing Tables.
About the CTI, we just need to follow the instructions on this link: http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K34599862
then, on phone B, you just CFwdAll the calls to *(and Phone B ext).
The main difference is that you should add a rule on the Forwarding table letting Unity know that if a call is forwarded from phone A, the system should send the call to the phone B subscriber's greeting.
Please try that and let me know how it goes.
11-10-2006 06:15 AM
Hi Esteban
Thanks for your information!
Coud you describe me your proposed solution with: add a rule on the Forwarding table letting Unity know that if a call is forwarded from phone A, the system should send the call to the phone B subscriber's greeting.
Thx
Marco
11-10-2006 06:09 AM
Hi Rob
Thank you for your information!
I couldn't find to configure on CCM :"OriginalCalledParty and OriginalCdpnRedirectReason fields in SCCP StationCallInfo message from CallManager"
Can you give me any hint?
Thx
Marco
11-10-2006 07:24 AM
Hi Marco
I'm not Rob but try to answer it anyway.
The parameters that Rob mentioned are not configurable. There is no way of passing the last redirect info from CallManager to Unity 4.0. A workaround (but just feasible for the Reception) could be to create a dedicated Voice Mail number for the reception on CallManager and with this number you may create a specific CallHandler in Unity that points to the reception mail box.
Stefan
11-09-2006 12:33 PM
Hi Marco,
11-10-2006 02:15 AM
Hi Marco
As Rob already posted, Unity is only looking at the first redirected number. In Unity Express 2.3 the mailbox can be (systemwide) selected by "Original Called Party" or "Last Redirecting Party". In Unity 5.0 it will also be a systemwide parameter. Will this be feasible for the normal users?
Stefan
11-10-2006 03:04 AM
Hi Stefan
Is there still a selection of "Original Called Party" or "Last Redirecting Party in Cisco Unity 4.0 Build 4.0(5)?
Thx
Marco
11-10-2006 03:48 AM
Hi Marco
No, it is not possible in Unity 4.0. Actually it is a missing feature of the CTI connection between Unity and CallManager (UnityTSP). It will be available in Unity 5.0
Regards and have a nice weekend
Stefan
11-10-2006 09:02 AM
Let me do a lab....
12-29-2006 04:46 PM
espereir
What was the final outcome in the lab? Were you able to get the call to go to the right VM using CTI RP/Unity forwarding rules or do we have to wait for Unity 5.0?
01-01-2007 11:38 PM
There is no solution until today, but I heard from Cisco directly there is a new feature in Call Manager Version 5.1 which solve this problem " divert a call by transfered calls".
01-02-2007 05:32 AM
A colleague of mine came up with a creative solution. I have not personally tried it
Route through a CMAC pilot and change the TCD system parameter ?Keep Original Called Party If Forwarded? to False.. Then make the always route member to a CTI RP that all call forwarded to VM.
01-02-2007 09:33 AM
Here are more details
"The big problem with modifying routing to voicemail is it keeps the first called party number, pretty much no matter what you do.. I.E. If you call ext 1000 and it forwards to vm, it will route into voicemail as a forwarded call with a called number of 1000. Also, if you call ext 1000 and it is forwarded to ext 1001 which is forwarded to 1002 which is forwarded to vm, it will still come into voicemail as a forwarded call with the original called number of 1000.
This characteristic seems to hold true for phones, cti rp?s and hunt groups. It even holds true for CMAC pilots, that is unless you change the TCD system parameter for call forwarding. The parameter ?Keep Original Called Party If Forwarded? is by default ?true?. If you change this to false and create a CMAC pilot with an ?always route member? to a CTI RP that all call forwards to VM, you will forward into voicemail for the DN of the RP, even if you call a station that is forward to the CMAC pilot, first. It will strip all prior forwarding off
