VIC2-2FXO picks up then hangs up
jfladouceur
Level 4
Level 4
Hi, I am having issues. All my VIC2-2FXO and VIC2-4FXO are picking up, then hanging up right away. I tried them on 1760s and 2811s. I tried a combination of supervisory disconnect, but can't get it to work. On 1760s, if I put a VIC-2FXO in the place of the VIC2-2FXO it works just fine. Is there a special command needed for VIC2s???
Ok, my mistake. I should have suggested "no battery-reversal". The default for "no disconnect signal" is power denial, that is not happening in your case.
18 Replies 18
paolo bevilacqua
Which exact IOS were you using? Can you take a trace with "debug vpm signal" and then send it with config.
Also can you try "no supervisory disconnect signal" under voice-port.
I tried that command on the FXO.
Router(config)#voice-port 0/3/0
Router(config-voiceport)#no supervisory disconnect signal
Oct 31 15:11:12.891: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Oct 31 15:11:12.895: htsp_timer - 125 msec
Oct 31 15:11:13.023: htsp_process_event: [0/3/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Oct 31 15:11:13.023: htsp_timer - 10000 msec
Oct 31 15:11:15.019: htsp_process_event: [0/3/0, FXOLS_RINGING, E_DSP_SIG_0100]
Oct 31 15:11:15.019: fxols_ringing_not
Oct 31 15:11:15.019: htsp_timer_stop
Oct 31 15:11:15.019: htsp_timer_stop3 htsp_setup_ind
Oct 31 15:11:15.019: [0/3/0] get_local_station_id calling num= calling name= calling time=10/31 15:11 orig called=
Oct 31 15:11:15.031: htsp_process_event: [0/3/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Oct 31 15:11:15.031: fxols_wait_setup_ack:
Oct 31 15:11:15.031: [0/3/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
Oct 31 15:11:15.303: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_DSP_SIG_0110]fxols_rvs_battery
Oct 31 15:11:15.591: htsp_process_event: [0/3/0, FXOLS_PROCEED_RVS_BT, E_DSP_SIG_0100]fxols_disc_confirm
Oct 31 15:11:15.591: htsp_timer_stop
Oct 31 15:11:15.591: htsp_timer_stop2
Oct 31 15:11:15.591: htsp_timer_stop3
Oct 31 15:11:15.591: htsp_process_event: [0/3/0, FXOLS_PROCEED_RVS_BT, E_HTSP_RELEASE_REQ]fxols_offhook_release
Oct 31 15:11:15.595: htsp_timer_stop
Oct 31 15:11:15.595: htsp_timer_stop2
Oct 31 15:11:15.595: htsp_timer_stop3
Oct 31 15:11:15.595: [0/3/0] set signal state = 0x4 timestamp = 0
Oct 31 15:11:15.595: htsp_timer - 2000 msec
Oct 31 15:11:16.955: htsp_process_event: [0/3/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Oct 31 15:11:17.595: htsp_process_event: [0/3/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Oct 31 15:11:17.595: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
show run
voice-port 0/3/0
supervisory disconnect anytone
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
Hi, this happens with all the IOSs that I have tried, with 2811 and 1760s. I reproduced the problem. I connected 2 2811 together. 1 with a VIC-4FXS/DID and the other has a VIC2-4FXO. I created a Dial-peer on the FXS router that points out the FXS port. When I go off hook with an analog phone and dial that dial peer. It rings, then disconnects me. This happens regardless if it's an analog phone calling or an IP phone calling, or even another gateway. Isn't the FXO suppose to pick up and play a dial tone???
****show voice port summary during the test on the FXO router****
Router#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/3/0 -- fxo-ls up dorm idle on-hook y
0/3/1 -- fxo-ls up dorm idle on-hook y
0/3/2 -- fxo-ls up dorm idle on-hook y
0/3/3 -- fxo-ls up dorm idle on-hook y
IN OUT
0/3/0 -- fxo-ls up dorm ring-det on-hook y
IN OUT
0/3/0 -- fxo-ls up up idle on-hook y
***Router#debug vpm signal**
Oct 31 14:36:42.347: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Oct 31 14:36:42.347: htsp_timer - 125 msec
Oct 31 14:36:42.475: htsp_process_event: [0/3/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Oct 31 14:36:42.475: htsp_timer - 10000 msec
Oct 31 14:36:44.447: htsp_process_event: [0/3/0, FXOLS_RINGING, E_DSP_SIG_0100]
Oct 31 14:36:44.447: fxols_ringing_not
Oct 31 14:36:44.447: htsp_timer_stop
Oct 31 14:36:44.447: htsp_timer_stop3 htsp_setup_ind
Oct 31 14:36:44.447: [0/3/0] get_local_station_id calling num= calling name= calling time=10/31 14:36 orig called=
Oct 31 14:36:44.455: htsp_process_event: [0/3/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Oct 31 14:36:44.455: fxols_wait_setup_ack:
Oct 31 14:36:44.455: [0/3/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
Oct 31 14:36:44.727: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_DSP_SIG_0110]fxols_rvs_battery
Oct 31 14:36:44.727: htsp_timer_stop2
Oct 31 14:36:45.015: htsp_process_event: [0/3/0, FXOLS_PROCEED_RVS_BT, E_DSP_SIG_0100]fxols_disc_confirm
Oct 31 14:36:45.015: htsp_timer_stop
Oct 31 14:36:45.015: htsp_timer_stop2
Oct 31 14:36:45.015: htsp_timer_stop3
Oct 31 14:36:45.019: htsp_process_event: [0/3/0, FXOLS_PROCEED_RVS_BT, E_HTSP_RELEASE_REQ]fxols_offhook_release
Oct 31 14:36:45.019: htsp_timer_stop
Oct 31 14:36:45.019: htsp_timer_stop2
Oct 31 14:36:45.019: htsp_timer_stop3
Oct 31 14:36:45.019: [0/3/0] set signal state = 0x4 timestamp = 0
Oct 31 14:36:45.019: htsp_timer - 2000 msec
Oct 31 14:36:46.379: htsp_process_event: [0/3/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Oct 31 14:36:47.019: htsp_process_event: [0/3/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Oct 31 14:36:47.019: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Router#
***************IOS**************
System image file is "flash:c2800nm-ipvoicek9-mz.124-9.T.bin"
Hi, you are getting a reverse battery signal:
Oct 31 14:36:44.727: htsp_process_event: [0/3/0, FXOLS_PROCEEDING,E_DSP_SIG_0110]fxols_rvs_battery
Have you configured "no supervisory disconnect signal" ?
show run
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
looks like it worked. Thank you so much
Glad to know it worked.
Beside the test, to what are you connecting, and in which country ?
Having same issue ... FXO goes to ring-det but doesn't answer.
Funny I'm not getting any output from debug vpm signal... yes I've done term mon...
I tried no battery reversal that didn't work...
tried resetting MGCP also...
no logging console was set DOH...
here's debug's
May 20 15:55:22.892 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_SETUP_ACK]
May 20 15:55:22.892 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
May 20 15:55:22.892 EDT: htsp_timer_stop
May 20 15:55:22.996 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:22.996 EDT: htsp_call_bridged invoked
May 20 15:55:23.144 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
May 20 15:55:23.144 EDT: htsp_timer2 - 350 msec
May 20 15:55:23.496 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
May 20 15:55:23.496 EDT: htsp_timer_stop
May 20 15:55:23.496 EDT: htsp_timer_stop2
May 20 15:55:23.496 EDT: htsp_timer_stop3
May 20 15:55:23.876 EDT: htsp_timer_stop3
May 20 15:55:23.896 EDT: htsp_process_event: [0/1/0, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
May 20 15:55:23.896 EDT: htsp_timer_stop
May 20 15:55:23.896 EDT: htsp_timer_stop2
May 20 15:55:23.896 EDT: htsp_timer_stop3
May 20 15:55:23.896 EDT: [0/1/0] set signal state = 0x4 timestamp = 0
May 20 15:55:23.896 EDT: htsp_timer - 2000 msec
May 20 15:55:25.896 EDT: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May 20 15:55:25.896 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
May 20 15:55:26.744 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
May 20 15:55:26.744 EDT: htsp_timer - 125 msec
May 20 15:55:26.872 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
May 20 15:55:26.872 EDT: htsp_timer - 10000 msec
May 20 15:55:28.888 EDT: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
May 20 15:55:28.888 EDT: fxols_ringing_not
May 20 15:55:28.888 EDT: htsp_timer_stop
May 20 15:55:28.888 EDT: htsp_timer_stop3 htsp_setup_ind
May 20 15:55:28.888 EDT: [0/1/0] get_local_station_id calling num= calling name= calling time=05/20 15:55  orig called=
May 20 15:55:28.892 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
May 20 15:55:28.892 EDT: fxols_wait_setup_ack:
May 20 15:55:28.892 EDT: [0/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
May 20 15:55:28.892 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_SETUP_ACK]
May 20 15:55:28.892 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
May 20 15:55:28.892 EDT: htsp_timer_stop
May 20 15:55:28.964 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:28.964 EDT: htsp_call_bridged invoked
May 20 15:55:29.144 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
May 20 15:55:29.144 EDT: htsp_timer2 - 350 msec
May 20 15:55:29.496 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
May 20 15:55:29.496 EDT: htsp_timer_stop
May 20 15:55:29.496 EDT: htsp_timer_stop2
May 20 15:55:29.496 EDT: htsp_timer_stop3
May 20 15:55:29.560 EDT: htsp_timer_stop3
May 20 15:55:29.576 EDT: htsp_process_event: [0/1/0, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
May 20 15:55:29.576 EDT: htsp_timer_stop
May 20 15:55:29.576 EDT: htsp_timer_stop2
May 20 15:55:29.576 EDT: htsp_timer_stop3
May 20 15:55:29.576 EDT: [0/1/0] set signal state = 0x4 timestamp = 0
May 20 15:55:29.576 EDT: htsp_timer - 2000 msec
May 20 15:55:31.576 EDT: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May 20 15:55:31.576 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
May 20 15:55:32.744 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
May 20 15:55:32.744 EDT: htsp_timer - 125 msec
May 20 15:55:32.872 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
May 20 15:55:32.872 EDT: htsp_timer - 10000 msec
May 20 15:55:34.888 EDT: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
May 20 15:55:34.888 EDT: fxols_ringing_not
May 20 15:55:34.888 EDT: htsp_timer_stop
May 20 15:55:34.888 EDT: htsp_timer_stop3 htsp_setup_ind
May 20 15:55:34.888 EDT: [0/1/0] get_local_station_id calling num= calling name= calling time=05/20 15:55  orig called=
May 20 15:55:34.892 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
May 20 15:55:34.892 EDT: fxols_wait_setup_ack:
May 20 15:55:34.892 EDT: [0/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
May 20 15:55:34.892 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_SETUP_ACK]
May 20 15:55:34.892 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
May 20 15:55:34.892 EDT: htsp_timer_stop
May 20 15:55:34.932 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:34.932 EDT: htsp_call_bridged invoked
May 20 15:55:35.144 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
May 20 15:55:35.144 EDT: htsp_timer2 - 350 msec
May 20 15:55:35.496 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
May 20 15:55:35.496 EDT: htsp_timer_stop
May 20 15:55:35.496 EDT: htsp_timer_stop2
May 20 15:55:35.496 EDT: htsp_timer_stop3
May 20 15:55:35.560 EDT: htsp_timer_stop3
May 20 15:55:35.576 EDT: htsp_process_event: [0/1/0, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
May 20 15:55:35.576 EDT: htsp_timer_stop
May 20 15:55:35.576 EDT: htsp_timer_stop2
May 20 15:55:35.576 EDT: htsp_timer_stop3
May 20 15:55:35.576 EDT: [0/1/0] set signal state = 0x4 timestamp = 0
May 20 15:55:35.576 EDT: htsp_timer - 2000 msec
May 20 15:55:37.576 EDT: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May 20 15:55:37.576 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
May 20 15:55:38.748 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
May 20 15:55:38.748 EDT: htsp_timer - 125 msec
May 20 15:55:38.876 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
May 20 15:55:38.876 EDT: htsp_timer - 10000 msec
May 20 15:55:40.892 EDT: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
May 20 15:55:40.892 EDT: fxols_ringing_not
May 20 15:55:40.892 EDT: htsp_timer_stop
May 20 15:55:40.892 EDT: htsp_timer_stop3 htsp_setup_ind
May 20 15:55:40.892 EDT: [0/1/0] get_local_station_id calling num= calling name= calling time=05/20 15:55  orig called=
May 20 15:55:40.892 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
May 20 15:55:40.892 EDT: fxols_wait_setup_ack:
May 20 15:55:40.892 EDT: [0/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
May 20 15:55:40.896 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_SETUP_ACK]
May 20 15:55:40.896 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
May 20 15:55:40.896 EDT: htsp_timer_stop
May 20 15:55:40.932 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:40.936 EDT: htsp_call_bridged invoked
May 20 15:55:40.936 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:41.148 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
May 20 15:55:41.148 EDT: htsp_timer2 - 350 msec
May 20 15:55:41.500 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
May 20 15:55:41.500 EDT: htsp_timer_stop
May 20 15:55:41.500 EDT: htsp_timer_stop2
May 20 15:55:41.500 EDT: htsp_timer_stop3
May 20 15:55:41.564 EDT: htsp_timer_stop3
May 20 15:55:41.580 EDT: htsp_process_event: [0/1/0, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
May 20 15:55:41.580 EDT: htsp_timer_stop
May 20 15:55:41.580 EDT: htsp_timer_stop2
May 20 15:55:41.580 EDT: htsp_timer_stop3
May 20 15:55:41.580 EDT: [0/1/0] set signal state = 0x4 timestamp = 0
May 20 15:55:41.580 EDT: htsp_timer - 2000 msec
May 20 15:55:43.580 EDT: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May 20 15:55:43.580 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
May 20 15:55:44.748 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
May 20 15:55:44.748 EDT: htsp_timer - 125 msec
May 20 15:55:44.876 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
May 20 15:55:44.876 EDT: htsp_timer - 10000 msec
May 20 15:55:46.892 EDT: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
May 20 15:55:46.892 EDT: fxols_ringing_not
May 20 15:55:46.892 EDT: htsp_timer_stop
May 20 15:55:46.892 EDT: htsp_timer_stop3 htsp_setup_ind
May 20 15:55:46.892 EDT: [0/1/0] get_local_station_id calling num= calling name= calling time=05/20 15:55  orig called=
May 20 15:55:46.892 EDT: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
May 20 15:55:46.892 EDT: fxols_wait_setup_ack:
May 20 15:55:46.892 EDT: [0/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
May 20 15:55:46.896 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_SETUP_ACK]
May 20 15:55:46.896 EDT: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
May 20 15:55:46.896 EDT: htsp_timer_stop
May 20 15:55:46.968 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:46.968 EDT: htsp_call_bridged invoked
May 20 15:55:46.972 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
May 20 15:55:47.148 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
May 20 15:55:47.148 EDT: htsp_timer2 - 350 msec
May 20 15:55:47.500 EDT: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
May 20 15:55:47.500 EDT: htsp_timer_stop
May 20 15:55:47.500 EDT: htsp_timer_stop2
May 20 15:55:47.500 EDT: htsp_timer_stop3
May 20 15:55:47.564 EDT: htsp_timer_stop3
May 20 15:55:47.580 EDT: htsp_process_event: [0/1/0, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
May 20 15:55:47.580 EDT: htsp_timer_stop
May 20 15:55:47.580 EDT: htsp_timer_stop2
May 20 15:55:47.580 EDT: htsp_timer_stop3
May 20 15:55:47.580 EDT: [0/1/0] set signal state = 0x4 timestamp = 0
May 20 15:55:47.580 EDT: htsp_timer - 2000 msec
May 20 15:55:49.228 EDT: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
May 20 15:55:49.580 EDT: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May 20 15:55:49.580 EDT: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
I would drop MGCP that is source of much troubles.
Yeah I hear ya...Would mean major overhaul for us.  Don't have time right now.
