AVAYA IP Phone with Cisco Catalyst switches
kaustav.gupta
I am facing this issue : AVAYA IP pHone when connected to a Cisco catalyst switch configured with Voice VLAN stops when the switch port is configured as a switch port access but when the same port is configured as Voice VLAN and the PC connected to the IP Phone is put in another VLAN the pc stops working but the phone works.Has anybody configured AVAYA IP phone with Catalyst switches.
kas
kleo
Level 3
Level 3
Does it work when if you try and explicit 802.1q trunk ?
like this :
interface FastEthernet0/1
description to IP telephone
switchport trunk native vlan
switchport trunk allowed vlan 1,,
switchport mode trunk
spanning-tree portfast
Second, how are you placing the phone in the voice vlan and what is the model of phone?
6 Replies 6
amit-singh
Level 8
Level 8
Hi Kas,
is the phone with inline power or the external adaptor support. Please paste the config of the switch and also the show version.
regards,
-amit singh
Int fastethernet mod_num/< port number>
Switchport mode access
Switchport voice vlan 192
Switchport access vlan 21
Spanning-tree portfast
Power inline auto
Mls qos trust cos
kleo
Level 3
Level 3
like this :
gopikrish
hi
configure the ports in trunk mode because in your configuration you configured the port in acess mode so it wont allow more than one vlan through the switch port
This is not how it works with the newer (2950 upwards) switches; only the 2900XL & 3500XL required the port to be specifically set as a trunk. The newer switches can be set to access ports with a voice vlan as described by an earlier poster.
I would have thought the problem lies with how the internal switch-port in the Avaya phone is configured. Generally you can set the IP Phone to set one 802.1q tag for itself and either no tag or a data vlan tag for the attached PC. The actual traffic between the PC and the IP Phone is untagged but the Phone can add on a tag and send it to the Cisco switchport.
How is the Avaya stuff configured? It may be worth hard-coding a port as a trunk and then setting up a span session to see what traffic is coming from the IP Phone, specifically what VLAN tags are you seeing.
Andy
loizosko
a couple things.
your port config is fine.
on your dhcp server make the following settings
on your scope for DATA vlan (21)
option 242 L2Q=1,L2QVLAN=192,VLANTEST=0
on your scope for voice vlan (192)
MCIPADD=192.168.10.10,MCPORT=1719,HTTPSRVR=192.168.10.10,VLANTEST=0
where 192.168.10.10 is your avaya system
you can also have more than one address there
