Telnet & Ping Problem
mansoor_nawaz78
I have problem in 2950 Switch, i configured a IP address on it, but when i try ping or telnet this switch, switch does not respond to my telnet and ping.
But when i check a SH CDP NEIG command on a connected switch, Switch display the switch, i have change th e IOS, i am connecting through the console port too, but no error message appears on the logg.
Thank You
12 Replies 12
Can you ping from your switch to some machine???
Have you defined the default gateway for your 2950??
If not then enter the following commands:
- enable
- ip default-gateway 'a.b,c,d'
Now try pinging your switch.
Hope this helps. Let me know if it works out.
AbhisheK
Please rate all posts!!!
Thank You for a reply,
I have configured a default gateway, ping is not working at all. not from switch to default gatway, and not from gateway to switch.
Thank
ok,
send us your config and ip address of your d/gateway
thanks in advance
Ajaz Nawaz
AJAZ NAWAZ
Level 5
Level 5
Mansoor
Have you assigned an IP address to the vlan1 interface?
Have you applied the 'ip default-gateway command'?
take a look at the following url:
<http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a008007e8bf.html#46167>
hth,
Ajaz Nawaz
desai.jaideep
Level 5
Level 5
Pls post the running-config of the switch.
JD
This is the configuration of my Switch.
Current configuration : 1805 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname testing
enable secret 5 $1$CY2p$jX3Rh4/Ez91np2TiSDael/
enable password br123
ip subnet-zero
ip name-server 192.168.0.10
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/24
switchport mode trunk
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 192.168.0.12 255.255.255.128
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
line con 0
line vty 0 4
password br12
login
line vty 5 15
password br12
login
end
Thank You.
Is your default-gateway a router?
If you can you please send us the interface config and routing table for that too please.
thank you
Ajaz Nawaz
No my default gatway is not a routter its a 3550 switch, and 2nd thng problem is in a switch, becuse when i use another switch with same configuration it start to work.
There is not any Routing issues.
When i connect a computer with the switch, computer start to work, everything work fine, but only TELNET and PING donnot start to work
Thank You
ok fine,
now send us please the output of 'show cdp nei detail' from the 3550.
Also I would like to see 'show ip int brief' from 3550 as well.
bye for now,
Ajaz Nawaz
I see you have interface f0/24 as a trunk , is this your uplink ? Do you have the far end setup as a trunk? If you don't need multiple vlans on the link then change f0/24 to switchport mode access and see if you can ping then .
Could u tell us wht is ur uplink port to 3550. and if possible, paste the o/p show interface vlan 1 command??
Rgs,
I have try, to change the trunk with swi mod acc, but still switch doesnot ping the default gateway.
Second thing my switch is not connected with a 3550 switch, my switch's next hope is 2950 then 3550.
Below is the output of sh int vlan1 command,
Vlan1 is up, line protocol is up
Hardware is CPU Interface, address is ff0b.5f12.1180 (bia ff0b.5f12.1180)
Internet address is 192.168.0.12/25
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 70000 bits/sec, 46 packets/sec
344495 packets input, 64960868 bytes, 0 no buffer
Received 72272 broadcasts (0 IP multicast)
0 runts, 0 giants, 11 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 576 ignored
6529 packets output, 472302 bytes, 0 underruns
0 output errors, 2 interface resets
