How to disable RIP and telnet on firepower 1140
MrBeginner
I would like to disable RIP and Telnet on firepower 1140 . But i don't know how to check RIP/telnet is disable .
let me know how disable RIP and Telnet on firepower and how to show they are disabled ?
2 Accepted Solutions
Hi, @MrBeginner
FTD by default not support telnet as per below guide. and as mentioned earlier , RIP is not working until you specifically enable it.
https://www.cisco.com/c/en/us/td/docs/security/firepower/623/fdm/fptd-fdm-config-guide-623/fptd-fdm-advanced.html
rate this and mark as answer if this solved your concern
Good luck
KB
Hello @MrBeginner ,
I have a pair of FP1140 in HA using FDM
the GUI has no option to configure RIP that you can configure using FlexConfig   ( access to ASA CLI) I'm in 6.6.4
So RIP should be disabled.
telnet connection should not be supported as noted
Hope to help
Giuseppe
5 Replies 5
use below document to configure/change relevant services.
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/fxos231/web-guide/b_GUI_FXOS_ConfigGuide_231/platform_settings.html#task_14A3611502A44A338EF0CCF15F3FBB58
RIP is disabled unless you configure RIP parameters.
Rate this and mark as answer if this solved your concern
Good luck
KB
balaji.bandi
Until you specifically enable RIP, its not enable by default.
You can check RIP Enabled or disabled here :
telnet
FTD does not support Telnet connections. Use SSH instead of Telnet to access the device CLI.
you can configure as below :
https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/200701-Configuration-of-Management-access-to-FT.html
BB
MrBeginner
Hi @balaji.bandi and @Kasun Bandara ,
Sorry for misunderstanding. I forgot to mention FDM . I am not using FMC.
Hi, @MrBeginner
Good luck
KB
Hello @MrBeginner ,
Hope to help
Giuseppe
