Routing
Labels
Hi im facing a problem im packet tracer file. The laptops (that im supposed to connect wirelessly to the the wireless router), adapter isnt turning on. Ive tried all the possible way that i know of. This is the file.
karo2307 by Community Member
  • 129 Views
  • 2 replies
Hello, I am picking a router for internet connectivity.  All I need is NATing, Static routing , VRF, IPSEC. I am planning to go for C8200-1N-4T. Bit confused whether I need DNA Advantage license or Essential is more than enough ? Please suggest
raghav.rai by Level 1
  • 47286 Views
  • 9 replies
We have a static route set on a pair of Nexus 9k (Connected with a VPC ) for a subnet pointed to our Palo Alto FW. We have numerous other static routes to the same IP. For some reason, on only the second 9K, this particular static route for ONLY this...
Hello all,Diving into the PIM "routing protocol" and have a few questions:PIM neighborships - if PIM does not send out any routing updates to its neighbors, what is the point of a PIM neighborship? (In my packet captures, all I ever see are PIM "Hell...
vv0bbLeS by Level 3
  • 178 Views
  • 2 replies
Good day team\collegues!Today I've upgraded cisco C8300-1N1S-6T to 17.15.4cIt has been deployed on 29th September https://software.cisco.com/download/home/286324476/type/282046477/release/IOSXE-17.15.4cI've converted to INSTALL mode and next is to in...
s_SiD_s by Level 1
  • 1060 Views
  • 15 replies
I have a new C8130-G2 router. This is my first experience with this platform. We are using this for some simple routing at a branch site. So no need for Advantage Routing license or SD WAN license. We are planning to just use the default Essentials R...
Bill by Level 3
  • 203 Views
  • 4 replies
Hi all, I'm posting for a group of students attempting to make a network for a class. We currently have a Cisco 2811 router we are configuring. We can ping within the local network but we can't seem to ping to the internet. We have tried everything w...
 Hi, i would need some help with proof of concept. We have 2 sites and we want to use QINQ. We want the Provider to be the one adding and removing the outer tag. So for ingress, the Provider add the outer tag ex 4000 and before it sends it out egress...
Tuff by Level 1
  • 307 Views
  • 2 replies
Hi team,  Besides the WAN ports on the IR8340/K9 device, the LAN ports also support routing (can operate at Layer 3). Thanks team
HatDauNho by Level 1
  • 384 Views
  • 7 replies
