Routing
Labels
I have old router series 3825 and running using version 12.4(13r), and want to know which latest version for this router? I try to lookup 3800 or 3825 in the software download but not found.
hs08 by VIP
  • 3 Views
  • 0 replies
I don't know how to solve task 6 and 7 simultaneously when we have to use two distribute list on a same interface. One for the access list on R2 and second for the prefix list on R2 towards R1. I need a solution ASAPRouting, EIGRRouting, EIGRPP
hi team,I have c9300 connected to SRX 340 via static route. I have also VRF on this switch with vrf default route through global. the VRF has  source multicast and needs to get out through global routing table.  VRF config po11no switchportip vrf for...
Resolved! ACL doesn't work
I am doing a lab on Cisco Packet Tracer and have reached the ACL stage.The course begins by giving small examples so that we can learn and understand the concept. But these examples do not work. I have been working on this for two hours, searching th...
ibrahimbdj by Community Member
  • 214 Views
  • 8 replies
Hei all, I was trying to find any information about this upgrade path through release notes, but it is lacking any information about steps in the upgrade. I was also getting through some forum topics already posted and went through few. It would be g...
Tomson by Level 1
  • 2834 Views
  • 4 replies
Hello,   I am trying to setup an IPSec VPN to a set of firewalls and I don't appear to have the isakmp commands under crypto. I read another post that I may need a separate license, is that still the case?   Thanks for your help!   (config)#crypto ?...
aastaguy by Level 1
  • 7889 Views
  • 6 replies
I hope someone can help me find an answer to this scenario. We have another organization with which we have a site-to-site tunnel. This tunnel is located at our home office. Our remote sites have site-to-site tunnels to the home office. The other org...
Resolved! BGP Issue
Hi,So this issue I have it drives me crazy lately so my last resort is here.I have the following topology. R4 <----> R7. Both connected through one Ethernet link in EVE-NG. The image I have is i86bi_linux-adventerprisek9-ms.156-3.M3a.bin but the same...
Road2CCIE by Level 1
  • 155 Views
  • 1 replies
as per my understanding ---stateful firewall means the device who keeps track record of flow from source to destination.and such firewall allow reverse flow i.e. destination to source if it is in its record so please explain in simple about this work...
knaik99 by Level 1
  • 232 Views
  • 4 replies
