Routing and SD-WAN
Labels
Welcome to the Cisco Community Ask Me Anything EventWe invite you to participate in our upcoming Ask Me Anything (AMA) conversation. Please submit your questions from Thursday, April 23, 2026, through Thursday, May 7, 2026. Our experts Eris Bleta, Mo...
Resolved! SDWAN Viptela NAT
I am working on a NAT configuration for a SDWAN Viptela install similar to below ip nat pool 123interface natpool1ip address 10.123.123.0 /24natstatic source-ip 10.123.200.30 translate-ip 10.123.123.30  outsidethis is a working installation the route...
MX-105 want port 1 SFP+ will not connectI have called support and their opnly suggestion is to buy a new GBICS.The GBICS I have work in all the meraki switches and lan SFP+ ports of ym mx-105I am at a loss here, and the purchase of a 750 to 1K gbics ...
jpliss by Visitor
  • 104 Views
  • 13 replies
Hello everyone i want to make ACL for CoPP but i have a doubt witch have to make it.ip access-list extended ACL-CoPP-IPsecpermit udp any eq isakmp any eq isakmppermit udp any any eq non500-isakmppermit udp any eq non500-isakmp anyorip access-list ext...
Mlex1 by Spotlight
  • 225 Views
  • 5 replies
Hello Everyone,We are having one issue with HSRP pair IE4K switches and ASA 5525 firewall in Cluster pair.The setup is attached file. Its basically a triangle with ASA firewall at the centre with 2 legs to the switches. The switches connect to each a...
lsp2310 by Frequent Visitor
  • 377 Views
  • 4 replies
Hey I have a Cisco ASA that connects to the same remote entity via two different firewalls using route-based VPN tunnels.I need failover built in from my side, so if the primary tunnel fails, I send traffic over the secondary tunnel (the reply traffi...
matirdamb95 by Community Member
  • 103 Views
  • 0 replies
IGMPv3 Max Response Code field uses an algorithm allowing values up to 52 minutes, but NXOS syntax limits the customer to 25 seconds. If a customer sets the command to 25, how is this number specified in the field in binary? Does it insert the number...
njccnp by Level 2
  • 202 Views
  • 3 replies
Dear All,I need your help to understand something. When I ran the automated script to install SD-WAN in CML 2.8, everything works as expected (https://github.com/cisco-open/sdwan-lab-deployment-tool/).When I decide to install manually each components...
hnavi77 by Level 3
  • 2214 Views
  • 7 replies
